Polk mm6501 hanging clip
vfx
There is a manufacturing defect on the clip. Do you know when it'll be fixed? I had been waiting on my speakers forever.
Post edited by vfx on
Hello,
Thanks for posting on the Forum. I'm checking with the folks in the Purchasing Department for a date. I'll give this to you as soon as I have information.
Regards, Ken -
Hello,
I was informed that they should be available near the end of September. I hope this is helpful.
Regards, Ken -
It's almost the end of September. Any words on the availability of Polk MM6501 yet?
Hi vfx,
can you tell me more about the manufacturing defect on the clip?
thanks
