LSi9's and Adcom 535
edited September 2008 in Speakers
Hello,
I have an Adcom 535L and will soon have some LSi9's. What is the best way to hook them up? Should I simply use one channel "A" or biamp by driving the low and high voicecoils separately with "A" and "B"? I know that this amp isn't a lot of power but it should be stable enough to drive the 9's at low to moderate levels. Anyone else try this combo?
Post edited by maximillian on
Welcome!
    Shouldn't really matter, especially if your speakers are close to the amp. The 535 is a 2 channel amp with 2 pairs of speaker outputs. if you wire it the latter method, you're basically biwiring the speakers.
    As long as you don't expect rock concert volumes, the amp will be fine. I used a 2535 (basically, 2 535's in one box) and it's been fine driving LSi series speakers.
    -Eric
    -Polk Audio
    Eric Wong wrote: »
    Exactly....so the question is: Do you want to bi-wire it? FYI - there are a LOT of threads debating this theory.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
    I would suggest not bi-wiring. I would suggest replacing the metal connectors on the LSi9 with a good quality wire jumper, then set back and enjoy the music.
    DKG999
    dkg999 wrote: »
    I just replaced my jumper with a coat hanger ;)
    Pre - Nak CA-5
    BR - LG BD390
    Eric Wong wrote: »
    So I can have my RTi6's and LSi9's hooked up at the same time as long as I don't run them at the same time. Is that correct? The reason I would want them together is because the 6's are for HT and the 9's are for music. Someday I will replace the CSi5 and 6's for an LSiC and not have all these speakers next to my TV.
    Thanks everyone.
    Is there a speaker switch on your amp?
    Ben
    Yes there is independent A+B switches. So I think as long as I don't have both of them activated the amp will see the load of just one of the speakers and I can have both of them hooked up.
    Yup. You'll be fine then. You probably won't hurt anything even if you do run both sets of speakers. Of course the resulting sound will be less then desireable ;)
    -Eric
    -Polk Audio
Welcome!
Welcome!
