LSi9's and Adcom 535
maximillian
maximillian Posts: 2,149
edited September 2008 in Speakers
Hello,
I have an Adcom 535L and will soon have some LSi9's. What is the best way to hook them up? Should I simply use one channel "A" or biamp by driving the low and high voicecoils separately with "A" and "B"? I know that this amp isn't a lot of power but it should be stable enough to drive the 9's at low to moderate levels. Anyone else try this combo?
Post edited by maximillian on
  • Eric W
    Eric W Posts: 556
    Shouldn't really matter, especially if your speakers are close to the amp. The 535 is a 2 channel amp with 2 pairs of speaker outputs. if you wire it the latter method, you're basically biwiring the speakers.
    As long as you don't expect rock concert volumes, the amp will be fine. I used a 2535 (basically, 2 535's in one box) and it's been fine driving LSi series speakers.
    -Eric
    -Polk Audio
  • curved
    curved Posts: 664
    Eric Wong wrote: »
    Exactly....so the question is: Do you want to bi-wire it? FYI - there are a LOT of threads debating this theory.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • dkg999
    dkg999 Posts: 5,647
    I would suggest not bi-wiring. I would suggest replacing the metal connectors on the LSi9 with a good quality wire jumper, then set back and enjoy the music.
    DKG999
  • curved
    curved Posts: 664
    dkg999 wrote: »
    I just replaced my jumper with a coat hanger ;)
    Pre - Nak CA-5
    BR - LG BD390
  • maximillian
    Eric Wong wrote: »
    So I can have my RTi6's and LSi9's hooked up at the same time as long as I don't run them at the same time. Is that correct? The reason I would want them together is because the 6's are for HT and the 9's are for music. Someday I will replace the CSi5 and 6's for an LSiC and not have all these speakers next to my TV.
    Thanks everyone.
  • ben62670
    ben62670 Posts: 15,969
    Is there a speaker switch on your amp?
    Ben
  • maximillian
    Yes there is independent A+B switches. So I think as long as I don't have both of them activated the amp will see the load of just one of the speakers and I can have both of them hooked up.
  • Eric W
    Eric W Posts: 556
    Yup. You'll be fine then. You probably won't hurt anything even if you do run both sets of speakers. Of course the resulting sound will be less then desireable ;)
    -Eric
    -Polk Audio
