sda 2b's
fourwheels0
fourwheels0 Posts: 23
edited September 2008 in Troubleshooting
i just got a pair of sda 2b's and want to know if i can use them with a yamaha rx-570 receiver (70wpc i beleive). will this receiver be ok to run the sda's?. i plan on upgrading my music source in the next month or two but i really want to listen to my sda's now.
Post edited by fourwheels0 on
    F1nut Posts: 50,836
    edited August 2008
    Yes, it will be ok. I would advise that you keep the volume level reasonable as that receiver will run out of steam very quickly.
  • fourwheels0
    edited August 2008
    ok great. i normally don't crank the volume anyways anymore. just wanted to make sure before i hooked them up. thanks.
    F1nut Posts: 50,836
    edited August 2008
    Yeah, I can't think of a receiver/AVR that isn't common ground.
  • candyliquor35m
    candyliquor35m Posts: 2,267
    Don't turn the volume past 12 o'clock and you'll be fine.
  • jtgranby
    jtgranby Posts: 887
    Bad advice start out at 7 o'clock and very gradually turn it up. I would not be suprised if you hear distortion starting at around 1000 o'clock. Like Jesse said his receiver will run out of steam quickly.
    What I am saying is do not start at 12 o'clock
    What kind of music do you listen to?
    Jim
  • fourwheels0
    lol i have not had the volume at 12 o'clock on anything in 15yrs or more(guess i'm getting old).i prefer quality over quantity lol.
    as for music i listen to classic rock,blues,vocals ect. basicly 60's to 80's stuff.
    i'm using monitor 10b's now with the rx-570 and never go past 9 o'clock and all is good. but the 10b's are 6ohm and the sda's are 4ohm so i'll have to keep an eye on the volume just to be safe UNTIL i can upgrade to more power!!!!.
  • candyliquor35m
    I'm the same way now but just 5 years ago, I would push my 2b's sometimes until the polyswitches tripped and the 6.5" mids started popping on 1 bass intensive cd.
  • dcmeigs
    dcmeigs Posts: 708
    Welcome. As you begin to upgrade, please audition a 200 WPC power amp; something like an Adcom 555 or Rotel. Your sound stage will expand greatly and the bass will become faster and punchier. I mention those two only because I have used them both with 2Bs with excellent results. There are many others that are as good or better. Enjoy.
    The world is full of answers, some are right and some are wrong. - Neil Young
