New SRS's
Jeff Beaird
Jeff Beaird Posts: 217
edited September 2008 in Troubleshooting
I'm sure this question has been asked; What is the parts list and what would it take to build a NEW set of SRS's? Are the parts still available? Is there a scematic on the internal bracing in the cabinets?
Hey, I'm a newbie still drooling about SDA's...
Thanks, Jeff...
Post edited by Jeff Beaird on
  • Jeff Beaird
    edited August 2008
    Nobody knows..? Or is it a Polk Secret..!:p
    Hello..!
    Thanks, Jeff...
  • fbm211
    fbm211 Posts: 1,488
    edited August 2008
    Ben built his own SDAs.There 7ft tall.Maybe he will chime in eventually and help you out.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    A few I have done...
    Here is an experimental cab that I tried different tweeter arangments with.
    http://www.polkaudio.com/forums/showpost.php?p=654292&postcount=141
    The big ones
    http://www.polkaudio.com/forums/showthread.php?t=53273
    Some 1c's I did
    http://www.polkaudio.com/forums/showthread.php?t=54554
    Some mini SDA's I am starting
    http://www.polkaudio.com/forums/showthread.php?t=71785
    Ben
  • zingo
    zingo Posts: 11,258
    edited August 2008
    Here is the components parts list for the SRS: (correct me and if I'm wrong anyone)
    Inductors
    4x .4mH
    2x .7mH
    4x 2.75mH
    2x 16mH
    Resistors
    2x 15ohm
    4x 22.5ohm
    2x 2.7ohm
    2x 7.5ohm
    Capacitors
    2x 4.4uf
    2x 12uf
    4x 20uf
    4x 130uf
    2x 92uf
    4x 750pf
    2x polyswitch (optional)
  • ben62670
    edited August 2008
    8 MW6503's
    8 MW6511's
    8 RDO198's
    2 15" PR's which you can't get from Polk
    Drop the 4 750pf's listed above.
    Lots of MDF, liquid nails, screws, .205 fast-ons, .105 fast-ons, and much asprin;)
    Ben
    F1nut Posts: 50,836
    edited August 2008
    ben62670 wrote: »
    8 MW6503's
    8 MW6511's
    8 RDO198's
    The SRS's would take the following in addition to the crossover parts Zingo listed.
    16 - MW6503's
    8 - RD0194-1's
    2 - SW150's (PR)
  • ben62670
    edited August 2008
    Missed it SRS is 194. Good eye Jessie!
    Ben
  • zingo
    zingo Posts: 11,258
    That's "Jesse" without the "i" Ben. :p
  • ben62670
    He reminds me from time to time. I am just used to writing my kids name:o
    Ben
