Trying to get my Computer hooked up to my receiver....
Shicks18
Shicks18 Posts: 397
edited August 2008 in Troubleshooting
So I tried ordering a USB to SPDIF and the converter only came with 3.5mm inputs, and no coax. So then I got online and tried ordering a 3.5mm to Coax adapter and it came, but the coax they advertised was for TV Cable!
I have a 25ft audio coax cable sitting here and I have no way of plugging it into my computer! I don't want to spend more than $20 getting this to work so my questions are:
Are there any cheap 3.5mm to Coax adapters or USB to Coax adapters?
Also, is it possible to take my 25ft coax cable, and change the terminator to fit in the 3.5mm to coax adapter?
edit: will this work? http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040109&p_id=680&seq=1&format=2
TV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3
Post edited by Shicks18 on
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    Is it a digital 3.5mm, or analog? We need to know what you have. Adapter link?
    Ben
    Ben
  • concealer404
    concealer404 Posts: 7,440
    edited August 2008
    Why don't you just get the cheapest sound card available that has an SPDIF out? I'm sure you could find one for $20, and you'd be using your reciever as a DAC anyways.....
    <EDIT>
    Check this out:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16829118103
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    It is the 3.5mm that comes from out of my laptop. I have my current laptop speakers plugged in there down. Basically a headphone jack.
    edit: I would need the sound card to plug into USB.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • concealer404
    edited August 2008
    Oh.... my bad.
  • ben62670
    edited August 2008
    Do you have digital out, or does the adapter have digital? Adapter link?
    Ben
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    This is what I bought:
    http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10311&cs_id=1031105&p_id=1614&seq=1&format=2
    I think it has S/PDIF out on it. But only in 3.5mm jacks. Other than that, my laptop doesn't have any digital outs.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • ben62670
    edited August 2008
    Real misleading add. That is just an analog usb sound card.
    Sorry
    Ben
    Ben
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    Its no biggy, I am shipping it back and gettin a refund. I think I am also going to take back the 25ft coax and get a 25ft optical. This should make it easier to find a working hookup, coorect?
    Thanks for your help
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • ben62670
    edited August 2008
    Ben
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2008
    Shicks18 wrote: »
    Actually no for two reasons it seams more audio cards have spdif than fiber. Also when I use my computer on my stereo i had the choice of fiber or spdif and i went back and forth and the coaxial sounded better. Just thought I would help ya out.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • ben62670
    edited August 2008
    Laptop;)
    I too agree with coaxial in the few tests I have done.
    Ben
    Ben
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    Well, for all of the lower end external soudn cards or usb dacs I only found optical =/
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • ben62670
    edited August 2008
    dee1949 wrote: »
    Analog outs. He needs digital. He has a DAC/receiver;)
    Ben
    Ben
  • dcarlson
    dcarlson Posts: 1,740
    edited August 2008
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
