altenator whine on sony xplode deck
vixentd
vixentd Posts: 1
edited August 2008 in Troubleshooting
No amp, just the head unit. Picks up altenator whine. Turn the lights on, even park lights and the whine goes away. This is a small rear engine powered fiberglass motorhome.
Grounds look good. Tried another positive source but didnt make a difference.
Have joined the yellow battery and red ignition wire to one lead, as we like to listen to the radio without the key in. Any suggestions appreciated.
www.vixenrv.org
Post edited by vixentd on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2008
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • pjtime
    pjtime Posts: 19
    edited August 2008
    Try a diffrent ground that should help
  • awe-d-o-file
    awe-d-o-file Posts: 146
    edited August 2008
    Make sure the speakers aren't grounded or that they share grounds between left and right channel. Disconnect the antenna and make sure you have agood ground from the ground wire and not from the antenna. Good luck!
    ET
    System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
    Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
    Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant!
