lost highs when volume is turn up too loud
PolkClyde
PolkClyde Posts: 662
edited August 2008 in Troubleshooting
on my 1.2's it didn't always do that. When I change my speaker cable it solve the problem years ago. What could be causing this problem again. Should I upgrade my speaker cables.I just purchase 8 new tweeters from Polk.As you all know These speakers are very old. 1988 is when I bought them.
PolkAudioClyde
Post edited by PolkClyde on
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited August 2008
    You may have to bypass the polyswitches but then you run the risk of damaging your tweeters.
    Or you can call polk and get some free replacement polyswitches. New ones may fix the problem or they may not depending on how hard you are driving them.
  • george daniel
    george daniel Posts: 12,096
    edited August 2008
    It sounds like you are tripping the polyswitches(tweeter protection), as they get older, they may trip with less volume and may do so more often. You can replace them,bypass them,,or keep the volume at a lower level. What are you driving them with?,,I think that I have a couple if you want em,,pm me--george
  • awe-d-o-file
    awe-d-o-file Posts: 146
    edited August 2008
    Sounds like the polyswitch doing its job. What amp are you using? Also why did you buy new tweeters? Which ones did you get? Same DCR/Impedance?
    ET
    System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
    Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
    Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant!
