tweeter problems
jjcool141
so im starting to have problems with my SR6500s.
The left tweeter is starting to go scratchy. if i put it louder it tends to clear up but at relativly low volumes it sounds pretty bad.
is there a way i can get a replacement tweeter?? If not i was thinking about getting a seperate set of tweeters, how would this work with the polk woofers???
any help would be appreciated!
thanks
J
thanks
J
Post edited by jjcool141 on
hi,
if you haven't already.. you may want to post your tweeter problem in the mobile audio section.. which is here. http://www.polkaudio.com/forums/forumdisplay.php?f=5
PolkFest 2012, who's going>?
