Audio Dialogue problems
joeygrand3
joeygrand3 Posts: 41
edited August 2008 in Troubleshooting
Somebody please help me.
I have a Yamaha entry level htr 5635 receiver(85 watts/channel) with Polk 30s front and rear. I have a Polk CS2 center and a Velodyne sub-woofer. The problem that I have is, when I play DVD movies the dialogue is not as clear as when I`m listening to the FM stereo, or 5 channel FM stereo. When watching DVDs I need to put the captions on so that I can clearly understand what is being said. I have tried using the 5 channel stereo selection on DVDs and still have the same problem. I have also tried different DVD players with no success. I have gone from a CS1 to a CS2 Polk center. I`m presently using a Samsung up-convert progressive DVD player. Does anyone think that my problem may be due to the entry level receiver? My TV viewing area is approximately 16x11/ This is part of a room that is 21x21 which houses the kitchen and the family room(AV set-up). The front speakers and the center are approximately 16 feet from my sitting area. my surround speakers are elevated approximately 3 to 4 feet behind the seating area. I have tried all the different receiver settings to improve the dialogue with no improvement. Other then buying another receiver I have run out of options. I`m afraid that if I do get another receiver that there would not be an improvement. If anyone can shed some light on this it would be much appreciated.
Post edited by joeygrand3 on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2008
    What are you using as your input for audio from the back of the dvd player and what type of player is it.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    I dont think its anything but the speaker. I recently went through this same problem with my father's center channel. We had to lower the bass control almost all the way, becuase dialogue was muffled.
    Result, tryed different center speakers until he landed on a speaker that did the trick.
    So after reading your problem, I believe its the speaker. Try another one of a different size, maybe smaller?
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • danger boy
    danger boy Posts: 15,722
    edited August 2008
    joeygrand3, are you using a optical cable from your DVD player to your receiver?
    you can go into the menu of your receiver and raise the volume level for your center channel.
    this is a very common problem people talk about. not being able to hear the dialog.
    PolkFest 2012, who's going>?
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    danger boy wrote: »
    Not to jump to conclusions, but I dont think its a volume problem. More of a clarity problem. If I'm not mistaken.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • danger boy
    edited August 2008
    jakelm wrote: »
    well that is a different problem then.. his tweeter might be blown if the dialog is muddy = not clear.
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    danger boy wrote: »
    I was thinking the same thing. Best he just try another speaker from BB or CC to see. Then return it if its not right.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Face
    Face Posts: 14,340
    edited August 2008
    You can all set your center to "NONE" or "Phantom" and the mains will receive the info that you center would have. I found this sounded better in my setup.
  • danger boy
    edited August 2008
    this is what I would do.. unplug your front, surround speakers.. and turn off or unplug your subwoofer. only leaving your center channel up and running. play a dvd movie and see how the center channel sounds. you should know pretty quick if something is blown on it.
