Single Voice Coil vs. Dual Voice Coil
AudioSystems09
AudioSystems09 Posts: 3
edited August 2008 in Troubleshooting
While not exactly troubleshooting problem, I am hoping for some advice...
I am considering purchasing the Polk MOMO MM2124 series 12" subwoofer, but I was wondering what the differences are between single voice coils and dual voice coils. Are there any benefits between one and the other? How would the specifications on the amp change? Would one make a better sub for exclusively techno music over the other? Would one "hit harder?"
Thanks!
Post edited by AudioSystems09 on
  • ShinAce
    ShinAce Posts: 1,194
    edited August 2008
    No.
    It's a gimmick to be able to better match the sub(s) to the amp(s). Make sure you get the proper TOTAL load.
    So if you want 4 speakers and your amp is 1 ohm mono stable, you would need each sub to come out to 4 ohms(single or dual voice coil).
  • jacob.simpson
    jacob.simpson Posts: 481
    edited August 2008
    still confusing how does dvc works and what should be the wiring to the sub should be.
  • ShinAce
    edited August 2008
    If you understand transformers and how they are wired up, a DVC sub is a center tapped sub.
    Basically, you cut the voicecoil in half and slap it back together to have 4 wires instead of 2. Same size voicecoil, same strength, just more ways to wire it.
    JlAudio has good tutorials:
    http://mobile.jlaudio.com/support_pages.php?page_id=145
    what you're looking for is:
    http://mobile.jlaudio.com/support_pages.php?page_id=163
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2008
    dvc is having to ohm loads of the same value in one speaker.
    Say you have a 4 ohm Single coil. Then the sub is simply a 4ohm woofer.
    But if you have a DVC 4ohm sub then you can wire it to be a 2ohm or a 8ohm sub with differant wireing configs.
    Try this link it should help you understand the wiring differances with single and dvc subs.
    http://www.crutchfield.com/S-BMz1vQfD4Uz/learn/learningcenter/car/subwoofers_wiring.html
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    This might be a crazy question but, the combined inductor's mH's dont double, do they? Meaning the low Fr cut doesnt change?
    If each coil was .90mH which gave a cut @ ~1khz. Things would not double if both coils were hooked?
    Giving, 1.80mH @ ~500hz?
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • ShinAce
    edited August 2008
    If the coils are wired in series, they add up.
    If they are wired in parallel, they divide.
  • Deadof_knight
    Deadof_knight Posts: 980
    edited August 2008
    more coils = more power handling ....and what he said ^
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
