Niles SSVC 2
szhleppy
I'm helping a buddy put together a home system. Here is the receiver he's getting:
http://http://www.crutchfield.com/App/Product/Item/Main.aspx?search=yamaha+663&i=022RXV663
He will have a 5.1 in the main room. For zone 2, he will have a pair of speakers in the pool room and also a pair of outside speakers....probably never using both at the same time. What do you think of this solution with the Niles SSVC 2 instead of going with a 3 zone receiver?
http://http://www.crutchfield.com/S-kNYmcq7XiqF/App/Product/Item/Main.aspx?i=190SSVC2
On a side note, I like this receiver because it has Pre Outs for when he wants to add a little more power to the system.
Thanks for your help.
Looks like I got the links wrong. The receiver is a Yamaha RX-V663.
Thanks.
