How to adjust a sx1250.1
mpdriver
mpdriver Posts: 1
edited July 2008 in Troubleshooting
I need to get a set of adjustments for this digital amp it has so many things to adjust I dont know where to start. If anyone has some help for me to get this amp pounding out my 2 l7 solobaric 12's that will be helpful. I dont know what lowpass,hipass,bandwidths,slopes,frequencys have to be set to for the best sound from amp.
Post edited by mpdriver on
  • Eric W
    Eric W Posts: 556
    edited July 2008
    You might want to ask on a Kicker forum :)
    All of the terms you mentioned are adjustments for the crossover (filters that only allow a certain portion of sound to pass through)- Usually for a subwoofer amp, you want to use the low pass filter, 24 dB/octave slope and freq set around 80 Hz, depending on your front speakers.
    -Eric
    -Polk Audio
