lSI9 5" DRIVERS DON'T WORK
Barbarian
Bought these speakers on ebay. the 5" divers on the right side are getting no power. Is there a quick fix or is this thing toast?
Post edited by Barbarian on
Barring the cables not being plugged in, call Polk customer service or drop them an email. They will have several options for you.
ebay is getting worse and worse. From bad products to scams
It could be as easy as disassembling the speaker and checking the wire connections. One wire could have gotten disconnected between the crossover and the driver during shipping, and you will get this problem.
First, obviously, make sure that your speakers are connected, and that you have external jumpers installed (in case of bi-ampable speakers).
Second, make sure that your drivers are moving and are not locked up.
Third, get a screw driver, carefully unscrew the drivers and the rear plate (with terminals) and inspect the connections between terminals, crossover and drivers. Make sure that there are no disconnected wires. If you find any, reconnect them.
Fourth, inspect the crossover for loose parts. Some parts could have broken off the crossover during shipping. In this case, you will need some soldering skills to re-attach the parts back.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
viper's right. pull it apart and look. something might have got goofy during shipping.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
