S10 Speakers buzz/vibration from mids
mallrat
mallrat Posts: 1
edited July 2008 in Troubleshooting
Both of my S10 speakers have a buzzing/vibration sound from the mid rang driver. When I touch the cone part the buzzing sound stops. Is there a way to fix this or do I need to replace the mids? If I do, where can I find the replacement parts? Thanks for the help!!
Post edited by mallrat on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited July 2008
    Hello,
    You can try taking the driver out of the cabinet, turn it 180 degrees and put it back in the cabinet. If the rubbing voice coil is only slightly warped the change in gravity will pull it away from the inside of the voice coil gap.
    Regards, Ken
