4 tube sets for Jolida JD100
treitz3
Ok, I know a lot of you have had or have a Jolida JD100 tubed CDP. I am currently running Sovtek12AX7LPS tubes. What I would like is to have 4 different [recommended] tube sets to play with. Price is not a concern but keep in mind I'm not looking for a rare set that costs thousands of dollars. All suggestions are welcome.
If you remember why [sound wise] you would recommend a particular tube set, throw me some of your knowledge. It's time to start some tube rolling.
Post edited by treitz3 on
The best 12AX7s I've used, imo, were Telefunken smooth plates w/ diamond bottoms. The only thing is, they tend to be a little salty."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Salty?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Expensive"SOME PEOPLE CALL ME MAURICE,
Tom, I have two "The Fisher" Telefunkens I bought from Russman some time ago. No idea if they are in good/bad condition and I have no tube gear right now. I'll ship them to you if you PM me your addy._________________________________________________
That's a very nice offer Ricardo, thank you. I believe that I will take you up on it. PM on it's way there, bro'.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Jesse and I had a discussion about this yesterday. Both he and I keep going back to the EI Gold Pins. I have the same Sovtek's. I put them in every once and a while but always put the EI's back in.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
I have a pair of Yugoslavian Ei 12AX7's, but the pins damn sure ain't gold. If memory serves, this is the one [Ei gold pin] that Jesse has recommended to others in the past.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
try the tungsol reissue ecc803s or ge 5751 5 star, i use them in my jolida 502a integrated amp.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
EI elite gold pins! They are the bomb in the Jolida CDP! I have the Sovtek LPS tubes, and they are good, just not as big of soundstage as the EI elites. I have some CBS Hytron black plates, but I couldn't really tell a difference between them and the EI elites.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I would go with the vintage tubes. Telefunken smooth plates, Bugle Boys, RCA clear tops and Mullards. The 12 AX7 family is filled with different flavors of tubes to enjoy. I tend to stay away from the new tubes, that's just me.Carl
I think I've tried just about everything, old and new including 5751's. The Ei's are still my choice.Political Correctness'.........defined
President of Club Polk -
what he said. I like the Telefunkens in mine and the IE's are good too.
You can find the Telefunkens on the Bay at times cheap. Also look for ECC83's.
ChuckTesting
Testing
Testing -
I dont know how they will work in your cdp, but the Mullard re issues work very well for drivers in my Jolida 502 amp. Very balanced top to bottom and great mid range.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
I agree about the Tele. It's the best X7 I've used.
If you want the complete opposite of Telefunken, try Mullard. They're warm, laid back and more full bodied.
For new production, the Ei is a Tele copy. They're made on Telefunken's machine.
JJ is also very good. Similar to Mullard. -
Any others before I order?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Ei Elite gold pins...you won't be disappointed!2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III -
The Gold pins are becoming harder to find since Ei is no more (purchased by Western Electric). The regular golds are just as good.
I did not like the Bugle Boys in mine at all. Way too laid back on the treble end. I liked the Svetlana and the Sovtek LPS.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Out of all the tubes I tried. The Solvtek LPS were the best IMO.
Nick -
For 12AX7's, smooth plate Telefunkens sound pretty good in my rig. As far as new production goes the Sovtek LPS gets my recommendation. When compared to each other the Teles have considerably more detail and smoothness, but the Teles also cost about four or five times as much money. I've yet to try a Mullard, Phillips or EI, but plan to do sometime in the future. (I have tried Mullard 12AU7 variants and they've help produce some of the best results on my equipment so far.) I also experimented with JJ's and RCA gray plates (the ones with the getter material on top) and both ended up deeply buried in my tube stash. While the JJ's were acceptable the RCA's were unlistenable. Nothing but grain, thinness and lack of detail. Just my 2 cents worth. Good luck in you search.Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
Cambridge Audio 640C V2 CD Player & Dacmagic DAC
Rega Planar 3: Deep Groove Subplatter, P3 Motor
upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor. -
Thank you for your input 55LS70, it's appreciated. Thanks to all of you. Any more suggestions?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
nikolas812 wrote: »Out of all the tubes I tried. The Solvtek LPS were the best IMO.
Nick
Same here,Ei Elite GP's,Electro-Harmonix,and I keep going back to the Solvtek.
Although I just put a pair of Amperex 12AU7A's in my pre...and I'm liking what I'm hearing. -
Hot damn, finally found a set of 12AX7 Ei gold pins thanks to someone on this board who was lookin' out for me. AWESOME!!!! Thanks! [You know who you are]~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I forgot the RCA/GE/Raytheon Blackplates. I replaced the Teles with them and was very pleased. Never tried the gray plates."SOME PEOPLE CALL ME MAURICE,
Damn, damn, damn. The daggum things were sold already. AAARRRRRGGGHHHH!!!!
From the A-gon seller...."Thanks for your offer--However, I have already sold them. I have been without power, and was not able to mark them as sold."
Damn. Damn. Damn. I need a beer now. Damn.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Damn. Damn.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
that is frustrating about the gold pins. I would like to know if there is a big difference on the gold pins vs the Ei.
So so far, what is your fave tube in there that you have tried. I am on day 3 of the EI ( not gold pin) and it is a bit more mellow in the bass over the Sovtek but it is starting to kind of loosen up and fall into place. I do like the mids and highs on it but the Sovtek had more boom. The Ei though seem more controlled in he bass not lacking it but more laid back in a way. Still letting them sing for another week or 2 before changing back to see the difference.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
