Power On, Lights Off, and Buzzing On
summertime
summertime Posts: 6
edited July 2008 in Troubleshooting
when I plug my Polk Audio I-Sonic ES 1, into the wall.. none of the lights go on, the only thing that happens, is a loud buzzing/humming noise starts up. everything is plugged in right i think,, whats wrong with it?!
Post edited by summertime on
  • summertime
    summertime Posts: 6
    edited July 2008
    can any1 help me with this please! :)
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited July 2008
    Are you talking about the light letting you know that there is power going to the I-sonic. Or light in your room?
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • zircon
    zircon Posts: 44
    edited July 2008
    are you talking about lights in your house?:confused: If so that usualy means you shorted somthing....
  • zircon
    zircon Posts: 44
    edited July 2008
    If your talking about an indicator light on the speaker or somthing then most likey you have somthing plugged in incorrectly. Check all connections twice.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited July 2008
    Hello,
    Your I-Sonic needs to come to our service facility, in San Diego. Telephone us at 1-800-377-7655 and we can help. You will need to provide us with the unit's serial number, which is found on the bottom, starts with "AM".
    Regards, Ken
