Panasonic 10a & Onkyo 805
dholmes
Sorry but my dumb a$$ is going to ask another question,why cant I get dolby hd to light up on my 805? The Onkyo is not receiving pcm,I thought I set everything correct on the Pany 10a.the movie I used was the Ruins which has the best pq Ive seen.What have I set wrong again,I had the same problem with my Integra 9.8 & you guy fixed it for me! thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
The Panny BD10A will not send 'Bitstream' to your 805, so you will never see TrueHD light up on your receiver. The 10A 'internally decodes' TrueHD and sends it out as Multi-channel PCM (over HDMI).
So, when you have a TrueHD disc in and everything is set right, the 805 will say "Multichannel". You will hear the same TrueHD, you just won't see it light up.
If you want that, you need the Panny BD30 or BD50, both of which can 'bitstream' the TrueHD, DTSHD Master, etc.See profile for rigs. Nothing else here. -
thanks billi willie,I thought I pissed u off for a minute,this cd burning is more trouble than de-fibbing a heart or intubating some oneMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
No, you didn't piss me off. I was just trying to urge you to just go for it. Its not as hard as it might seem and you don't have to worry about turning your receiver into a brick.See profile for rigs. Nothing else here. -
On the Pany 10a should I set everthing in the menu to pcm or bitsream?My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Also what is the big difference between the Pany 30 & the 50 when it comes out? Is it just the bd live stuff/ thanksMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Make sure Re-master, V surround, Dialog Enhancer, Digital Filter settings are all set to OFF. (these are accessible through the onscreen menu which comes up when you press DISPLAY)
In the Setup Menu
Dynamic Range Compression-Off
PCM Downconversion-Off
DolbyDigital-Bitstream
TrueHD-PCM
DTS-Bitstream
DTSHD-PCM
BDVideo Function Sound-Off
Make sure HDMI Audio Output is on,
and of course, have the bluray hooked to the 805 with an HDMI
That should do it.See profile for rigs. Nothing else here. -
I believe the 10a internally decodes but doesn't bitstream. The 30 bitstreams but doesn't internally decode. The 50 does both and does the bd live stuff as well. -
That sums it up exactly.See profile for rigs. Nothing else here. -
ThanksMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
