LSiFX Woofer Rattles
hockeyboy
hockeyboy Posts: 1,428
edited August 2008 in Troubleshooting
The left side woofer (the one above the bipole switch) on my LSiFX has started rattling. I ended up having to disconnect the speaker. Any suggestions?
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus
(Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
Post edited by hockeyboy on
  • hockeyboy
    edited July 2008
    Okay I took the woofer out this morning and it appears that there is something wrong specifically with that one woofer. This LSi is only about 14 months old and treated very well. Would it be possible for Polk just to send me another woof for it?
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
  • orgthtogod
    orgthtogod Posts: 41
    edited July 2008
    hockeyboy wrote: »
    Is it "distorted" or just rattling? I have a similar situation with an LSI-15 right now. I have a new tweeter coming and a mid driver too.
    If you need to replace anything make sure you mention your membership here as you will receive a nice discount!
    By the way, I bought my LSI-15's used, were your FX's new or used? I have the FX's as well and have had no problems...
    Good luck!
  • orgthtogod
    edited July 2008
    hockeyboy wrote: »
    Just saw your post... I somehow missed it...
    Anyway, YES, call polk and you can get a replacement no problem. I don't know about any possible warranty or not, but with your forum membership it shouldn't run you any more than about 40 bucks or so with shipping and the discount!
  • hockeyboy
    edited July 2008
    Thanks, I called and spoke to customer service and have a new woofer on the way. They gave me a great deal since I am a forum member.
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
  • hockeyboy
    edited July 2008
    :D:D:D:DI got my woofer yesterday and installed it last night. Happy to report, problem solved. Thanks for a quick and easy repair Polk!:):):):)
    My Main Gear
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    (Passive Subs)
    Panamax M5300EX
  • Shannon W.
    Shannon W. Posts: 568
    edited August 2008
    Ken at customer service for Polk is Tops in my book. when the LSiC first came out there was a problem with the cross over. when you listened at a high volume and it was close to a CRT television it would distort the color of the TV. I called ken ASAP and he confirmed they knew about this problem and in two days I had a new cross over sent to my door free of charge.
    BTW! THANK YOU KEN!
    Shannon
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
