How to add an non-factory amp to my sub?
miky702
miky702 Posts: 4
edited July 2008 in Troubleshooting
I have a polk psw1200 that has a non-functional amplifier. It'd cost 330 to have my old one replaced. I don't want to spend 330 on an amp. With that money, I could get a new powered sub if I spend a little more. I don't want my psw1200 sitting at home doing nothing either. Anyone has put a different brand amp to his old polk sub before? Any recommendations on what to get and how to do it?
Post edited by miky702 on
  • zingo
    zingo Posts: 11,258
    edited July 2008
    These plate amplifiers are pretty popular and might be plug and play, but you might have to take measurement to make sure.
    The other option I would look at is disconnecting the amp from the driver, and wire the driver into a new set of binding posts added to the cab. Then you could use any external amplifier that you wanted, and would only need to drill two holes for the posts.
