Here's The Most Craziest Thing That Happens And Need Answers?
joker187
joker187 Posts: 25
edited July 2008 in Troubleshooting
so i got a kenwood KAC-9125D it runs at 500wx1@4 ohms 900wx1@2ohms 1800w max. theres a + + - - if i hook both up seperate will the 1800w apply or will it split the power in two?
also i had it hooked up blew the battery fuse, changed the fuse turn car on and it workd. turned off, turn key back now it don't work...HERE'S THE MOST CRAZIEST THING THAT HAPPENS AND NEED ANSWERS?
i put a screwdriver to the gnd screw try to unscrew it and touch the amp with the screwdriver.....light comes on it works when i take it off it doesnt?when i lean the screwdriver on the amp when touching gnd screw on amp it work, when i dont lean it comes off? wtf is goin on, hooked up other amps they work just fine, need a bigger wire i got a 8awg(500w rms) running to it?do i have a short in a wire?is the amp i protect mode. Hooked up to another vehicle works fine?
Post edited by joker187 on
