C300.2 amp gives me the short/low ohm light.
Anthony92x
Anthony92x Posts: 2
edited November 2008 in Troubleshooting
I honestly don't believe I have a short. I've checked the fuses. I have 12.6volts at both the 12V and remote terminals.
When I turn on my head unit, the red short light comes on briefly and then fades dark. Then it occasionally flickers on and off.
Any ideas?
Post edited by Anthony92x on
  • Anthony92x
    Anthony92x Posts: 2
    edited July 2008
    And, I've not getting any sound out of the sub. The other C300.2 that powers my front speakers works fine.
  • [Deleted User]
    [Deleted User] Posts: 0
    edited July 2008
    Disconnect the speaker/s that are connected to the amp and turn it on see if the light acts normal if so your speaker or wire has a problem. Also check your underhood fuse for corrosion, as well as ground wire connection.
  • PolkThug
    PolkThug Posts: 7,532
    edited July 2008
    My 300.2 just started doing this also! It doesn't matter if the speakers are attached or not, that light will slowly blink. If the speakers are attached, I get sound - no sound - sound -no sound, etc.
  • bullett4006
    bullett4006 Posts: 1
    mine is doing the same. i cant figure out why. i have tried pulling out the speaker wires, and it still just sits there blinking. a friend of mine that runs an audio shop is coming by tomorrow to help me with it.
    ill let yall know what i figure out.
