ideal speaker to listening position distance
Norm Apter
Norm Apter Posts: 1,036
edited July 2008 in 2 Channel Audio
I realize that this is a matter of personal preference, but I wanted see what others -- especially those who have done experiementing with speaker position -- feel is an ideal distance between your speakers and your listening position for your 2-channel set-up.
I think that arranging things in living rooms is probably easier than bedrooms because of the common configuration of TV/Entertainment unit up front and sofas centered in rear. Unfortunately, I spend A LOT more time at my desk --which is up against a wall -- in my bedroom, so it just wouldn't make sense to put my 2-channel rig in the living room. I've done some experimenting with my speakers' (Lsi9s) position and have found that if they are too close to me, I am really limited in the volume I can tolerate (in other words, my head will start to hurt at even moderate listening levels). Thus, I'm especially interested to hear from those who have also been navigating the tricky waters of 2-channel bedroom listening. Any thoughts? Does anyone adjust L-R balance to compensate for less than ideal listening configurations?
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
Post edited by Norm Apter on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited July 2008
    It is HIGHLY dependent upon the type of speaker, speaker size, room size. However, I've found the sweet spot to generally lie between an equilateral triangle of you & the two speakers & a few feet behind that spot.
    Have you tried a good set of headphones?
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Norm Apter
    edited July 2008
    TNRabbit wrote: »
    Yes, I had read about the "equilateral triangle" ideal and am sure that it is a good guideline to follow. Unfortunately, it just doesn't seem feasible given the the layout of my room and listening position (i.e. I don't have the space to place my desk in the middle of my room) and thus I'm trying to do the best I can in tough conditions. Right now, there is much more distance between the two speakers than between each of them and me.
    As for headphones, yes eventually I want to spring for a pair of Sennheiser-595s. But this would be primarily for late-night listening (to avoid disturbing my wife). During the day, I'd still like to make use of the Lsi9s.
    2 Ch.
    HT
    Denon 2808ci AVR
  • steveinaz
    steveinaz Posts: 19,545
    edited July 2008
    My speakers are about 8ft apart, 9.5ft from my primary listening couch, with a 1/2" of toe-in. I have the benefit of a large room, and good flexibility with placement. The room is actually a "great room" with livingroom, dining room, and kitchen all occupying the same space. Approx 36' x 18' with 12ft vaulted ceilings. The listening area is the first 13ft x 18ft of space. Due to a 45 degree corner fireplace, I couldn't spread my speakers any further out.
  • TNRabbit
    edited July 2008
    Norm, do you have a diagram of your current layout?
    TNRabbit
    Sunfire TG-IV
  • Norm Apter
    edited July 2008
    Well, I don't have a diagram but I just took two pictures in an effort to give a sense of the set up. The length (about 14 ft. Yikes!) between the speakers made it nearly impossible for me to get both in the first pic (I would have needed a wide-angle lens for this, which I don't have). You can just barely make out one part of each speaker on the cental far left and far right portion of the photo. My listening position is the chair. The speakers should be easier to make out in the second photo (I hope the photos come across. I had to paste them to a Word doc and convert to PDF which I've attached since I don't have any URLs to link).
    2 Ch.
    HT
    Denon 2808ci AVR
  • mantis
    mantis Posts: 17,453
    edited July 2008
    If you want to hear what your speakers can do , then follow the equal triangle guide lines and you will be cool. Go outside of that and lose performance you will.
    All speakers made basically work with in these guide lines. It works well. I have set up thousands of speakers and always find myself going back to the basic rules. They have never done me harm.
    If it is not possible to follow the guide lines, then try to get as close as you can. I good place to start is look at both your speakers from your listening position, if you can see the sides of your speakers then you do not have them set up correctly. Set them up so you only see the front of the speaker. This will help alot.
    Good luck
    Dan
  • organ
    organ Posts: 4,969
    edited July 2008
    See if you can re-arrange the room. Like others have mentioned, I find the equilateral triangle to work out 95% of the time. A laser pointer also helps a lot for toe-in.
  • Norm Apter
    edited July 2008
    Thanks, guys.
    OK, I decided that major re-arrangement is in order (my wife is currently visiting family in Taiwan for two weeks so this is as good a time as any). The crazy thing is that our room is actually triangular-shaped -- not kidding -- but, unfortunately, this does not lend itself to creating that sought-after listening equilateral triangle, when you factor in the other pieces of furniture (i.e. queen-sized bed). Nevertheless, I think I've finally come up with something and have begun to re-arrange accordingly. Looks like I won't be able to achieve the perfect triangle -- the distance between the speakers will be a little shorter than the distance between each of them and myself at listening position -- but this will be preferable, I believe, to the old set-up where the distance between the speakers was about 3 times the distance between them and me. As you might imagine, there was entirely too much separation there (like listening to two mono recordings simultaneously). Will post pics when things are in place....
    2 Ch.
    HT
    Denon 2808ci AVR
  • mantis
    edited July 2008
    Norm Apter wrote: »
    Thanks, guys.
    You know sometimes if the room just doesn't allow it, going inceiling might be the way to go man. I have had complete systems in the ceiling and man when properly setup , they sound fantasitc.
    Other choice is to choose a better room IF your serious about your performance.
    Dan
  • fossy
    fossy Posts: 1,378
    edited July 2008
    6ft. -- cause that's all the room i have in the bedroom:D:D
    my ears ring ............and ring ........ and ring ... but I love it :rolleyes:
    Maybe i think i should start taking over the livin room next ......
