RT800 Bad 6.5 Driver?
NDgamer
hey guys i have a RT800 and one the drivers are cracking at a low volume but turned up a bit goes away this driver sound blown? if so anyway to get a replacement somewhere est. price? and does anyone know how to properly take these things apart such as the front panel with the two drivers?
thanks in advance
thanks in advance
Post edited by NDgamer on
if it was blown, no sound would be forthcoming. swap the channels around and see if the distortion follows the speaker. if the distortion remains on the same channel. there could be a problem with the amp... maybe the volume pot needs cleaning.
if the distortion follows the speaker, then further investigation would be needed, you could try swapping the driver with the other speaker. If the distortion follows the driver, then the speaker is the culprit. if not, then it could be the crossover. -
if the cross over was bad both speakers wouldnt work the crossover runs on both of them ive ran just one speaker alone if i apply pressure to the cone it goes away i belive because the coils are fired and when pressure applied gets a connection anyone know where i can get a replacement or call and how much it costs?
if the crossover is bad, it is still possible for one speaker to work and the other not... swap drivers and see if that works... otherwise call Polk support for a new driver...
well i belive its forsure the driver but i think the drivers are glued in unless theres a way to take it out? does anyone know?
I have a pair of RT800i's the driver is held in place by the plastic cover use an allen wrench take of the cover and the driver will come out. The driver is not screwed in or glued.TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX
