Advice needed on power conditioners/surge protector
NotaSuv
NotaSuv Posts: 3,871
edited July 2008 in 2 Channel Audio
What are you using? Same piece for both functions? The more I search the more varied the opinions are.....no experince in this area besides the cheap $20 power strip....for use with system below....thanks in advance for any input..budget to around 500/600...have no problem buying used equiptment as 90% of my system was bought used....
Post edited by NotaSuv on
