Blown Speakers
jstrang
jstrang Posts: 5
edited June 2008 in Troubleshooting
Hey I have a pair of RTi10s and the midrange driver blew from being turned up too loud i think. Then the other day I pulled my computer forward and it yanked out the audio cord in the back leading to my receiver while music was playing, and when I plugged it back in both my tweeters gave me no sound :mad:
So my question is are the tweeters blown or could it be something else? and does warranty cover this or was it my fault and I have to buy new parts?
Post edited by jstrang on
  • jon s
    jon s Posts: 905
    edited June 2008
    if you played it too loud and the midranges blew, chances are you blew the tweeters before that... Abuse is not covered by warranty so the repair is in your wallet...
  • jstrang
    jstrang Posts: 5
    edited June 2008
    i blew ONE midrange probably about 6-7 months ago and i have just been using the one speaker in my setup until recently when i replaced the midrange and started using them both again. now my tweeters both stopped working
    The midrange blew after a party when i had them hooked up to a 500 wpc amp and the tweeters just stopped working a few days ago hooked up to a kenwood 220wpc amp
    are my tweeters blown or could there be something else preventing them from playing?
  • deep bass
    deep bass Posts: 86
    edited June 2008
    pull them out and take a gander?
    F1nut Posts: 51,778
    edited June 2008
    Is the Kenwood an amp or an AVR? At what volume level did you have it at?
  • danger boy
    danger boy Posts: 15,722
    edited June 2008
    party level volume.. what does that tell you Jesse? 1 or 2 o'clock on the volume knob most likely. :eek: :mad:
    jstrang, first off welcome to club Polk... if you push any speaker beyond it's limits it will blow.. either a tweeter, mid range or woofer, depending on it's design.
    if you like to play your speaker loud for parties. consider buying a cheap azz pair of dance club type speakers..
    PolkFest 2012, who's going>?
    F1nut Posts: 51,778
    edited June 2008
    So it would seem.
