What to do with Broken HD-A2
pmlewis
I was so excited when I found a new, unopened HD-A2 at my local Walmart. I knew that I was getting and HD TV and was going to by an up converting DVD player anyway so when I saw this for $74.99. Well I finally got my TV and hooked up the A2. The picture was great for all of 10 minutes and then it froze.
:eek:
I cleaned the disk, cycled the machine, tried other DVDs but always the machine says no disk when a DVD is loaded. I put in a CD-R and it recognized it right away. I then downloaded the latest firmware which loaded fine, but still no disk with DVDs. I tried compressed air but no luck. Today I called Toshiba and they said they would exchange it for and A3, but I have to pay shipping to Lebanon, TN.
Should I spend the extra money and get a replacement A3 (probably a refurb), or should I just return it to Walmart and get my money back?
:eek:
Post edited by pmlewis on
If it were me, I would just return it. They will give you a refurb in exchange.
and I'd take the exchange for an A3...
Fire.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Do you own a Boat?Dan
Take it back. You can find better deals for better players on ebay.Proud SOPA Member since 2005!
Probably needs a firmware update"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Will it blend?
You probably just need to do the firmware update.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
In case any one cares I took back the A2 to Wal-Mart and wound up finding an HD-A30 at a local pawn shop for $5 less. Everything seems to be working fine for now. Thanks for all the input.:D
Beware of the Firmware 2.0 update for the A-30. Let us (me) know if you have any problems with combo disks.
http://www.avsforum.com/avs-vb/showthread.php?t=992822Proud SOPA Member since 2005! -
Have you tried to unplug it for about 5 minutes and then plug it back in?If...
Ron loves a film = don't even rent.
