CS400 Question
tecmo04
tecmo04 Posts: 421
edited June 2008 in Troubleshooting
On such a lovley Sunday morning i decided to start tinkering around with all the speakers (i.e. tightening all the connections...) and i noticed my cs400 sounds a little funny. It seems as if the left woofer plays more of the highs and the right woofer, which is much quieter, plays more of the bass. There is definitely sound coming out of both but its not the same.
Any ideas whats going on?
Thanks!
Post edited by tecmo04 on
  • Jed Leland
    Jed Leland Posts: 183
    edited June 2008
    Hello,
    I believe that center channel speaker has a cascaded crossover, meaning the two drivers don't reproduce the same frequency spectrum. If you look at Polk's technology page they describe what this is. There's nothing wrong with your speaker that's the way its supposed to sound, my friend.
    Cheers, Jed
  • amulford
    amulford Posts: 5,020
    edited June 2008
    That is 100% correct. If it didn't, you would get comb filtering, which is bad...
  • danger boy
    danger boy Posts: 15,722
    edited June 2008
    your CS400 speaker is working 100% like it should. no problems.. sit back and enjoy!
    PolkFest 2012, who's going>?
  • tecmo04
    tecmo04 Posts: 421
    edited June 2008
    thanks for the reassurance! at first i thought i was crazy...
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2008
    Enjoy your CS400! :p
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • tecmo04
    tecmo04 Posts: 421
    edited June 2008
    so why can floor standers have two woofers pay the same music like my monitor 70's. which is better?
  • zingo
    zingo Posts: 11,258
    edited June 2008
    "When two speaker drivers are placed near each other, destructive interference between the two drivers in the upper-midrange creates frequency response errors (called "comb filtering") and degrades imaging. This also collapses the sound stage and narrows the dispersion capability of the speaker.
    To solve this problem, multi driver LSi, RTi towers, Monitor towers, TSi towers and high end CSi models use "Cascade Tapered Array" crossovers. One driver is crossed over much lower in frequency and is in essence a bass-only driver. Only one driver plays the upper midrange frequency range thereby eliminating the interference effects between the two drivers.
    You get the best of both worlds - the dynamic impact of multiple drivers with the accuracy and life-like imaging of a single driver system."
  • danger boy
    edited June 2008
    it's not a matter of which is better.. both are different and used in different applications. I would think the difference is in the crossover design.
