Bi-ampable CRS+
zingo
zingo Posts: 11,258
edited May 2008 in Vintage Speakers
Has anyone ever modded their CRS+ (4.1TL) to be bi-ampable? I was looking at the x-over trying to figure out how it would work. This is what I came up with but I could be way off...
Post edited by zingo on
  • Face
    Face Posts: 14,340
    edited May 2008
    HF looks fine, but reversed. LF doesn't appear totally right to me, besides being reversed also. :)
    I did this quick with paint. I would wait on Jesse or someone else who knows more to chime in though.
    F1nut Posts: 51,789
    edited May 2008
    For a speaker that size, why bother?
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2008
    It's as neat of an idea as making it a 4.1TL in my book. Why not?
  • zingo
    zingo Posts: 11,258
    edited May 2008
    I'm running an Outlaw 7100 because of my integrated 2 Ch and HT. I figured since I have two extra channels on the amp and not a lot of extra money right now, I could double the power going to the speakers since they are only recieving about 110wpc.
    The other point is that I also have a Carver Pm1201 that I could use to power them with about 400wpc, but the SQ is better on the Outlaw, so I figured higher SQ is better than higher power. What do you think?
    Plus, they have already been recapped, 4.1TLed, and RDOed, this is the next step, right... :D
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2008
    You may need to do some crossover modifications to adjust the impedances once the HF and LF sections are split.
    I recall reading about someone who split the crossover of his 1C's, but I don't remember where I read it.
    I have also read posts on splitting the crossovers of other speaker brands on some DIY forums, but I do not recall the specifics of those either.
  • NotaSuv
    NotaSuv Posts: 3,871
    edited May 2008
    why not bother? always fun to try new things
    F1nut Posts: 51,789
    edited May 2008
    NotaSuv wrote: »
    As good as the 4.1TL upgrade makes the CRS+'s any further tweaking benefit is going to be limited by the cabinet size, the number of drivers and Raife's point. But, that's just my $.02, so knock yourselves out.
  • zingo
    zingo Posts: 11,258
    edited May 2008
    Per DKs prodding, I was searching old posts and someone mentioned a PDF for a bi-amp upgrade but there was no link. So I PMed Ken to see if it's floating around head quarters and I'll let you know what I find out.
  • amulford
    amulford Posts: 5,020
    edited May 2008
    I would be careful, as Raife said, your going to have to adjust the impedances or your going to put the tweeter thru the wall.
    F1nut Posts: 51,789
    edited May 2008
    Reported, now get lost!
  • amulford
    edited May 2008
    Did you check those links out??? WTF???
    I top you and I are also top-Jin top
    Small world...
    F1nut Posts: 51,789
    edited May 2008
    amulford wrote: »
    Small world...
    I never click on spam links.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    zingo wrote: »
    You are right. The inductor has to be between the ground, and the rest of the circuit. I would not bother though. Too much work for really no gain. You would have to play with the levels of the amps, or put a resistor in the signal path of the tweeter.
    Don't both dude really. Remember this is coming from a guy who has to tear into nearly everything he gets.
    Ben
    Ben
