bi-polar surround upgrade
gtbiker
gtbiker Posts: 15
edited January 2003 in Speakers
Hey guys, I'm finally upgrading my surrounds. I already have the LSi ctr & LSi9's anchored by the PSW1200. Of course I want the LSI bi-polar surrounds but they are too expensive. Right now my choice is the Definitive Technology BP2X bi-polars. They have two 5 1/4 midbass drivers & two tweeters per speaker. I can get them from 6th Ave for $500. Anyone have any feed back on the Def Tech speakers and what are some other choices for $500 bi-polar speakers that have two midbass drivers and two tweeters per speaker?
LSi9, LSiC, PSW1200, Definitive Technology BP2X surrounds, Sony rcvr STR-DE435, Panasonic DVD-RA60
Post edited by gtbiker on
  • brettw22
    brettw22 Posts: 7,624
    edited December 2002
    Really for $100 more, you could get the LSiFX surrounds to match your current setup.
    The link is http://sounddistributors.com/productlist.asp?crid=56&pcrid=40&cat_name=Surround+Speakers.
  • marvelous
    marvelous Posts: 38
    The definitive tech surrounds are very good speakers. They blend very well with polk speakers. At one time I had the 2300 center channel and it worked great with SDA 3.1tl and CRS. If the sound distributors does not come through this would be a good fit.
  • gtbiker
    gtbiker Posts: 15
    Just got the Def Tech BP2X today as a Christmas present from my fiancee. ( If I spend another dollar on HT stuff she wiil kill me ) I will be patient with my review until I have them for awhile but I tested them with Resident Evil today which has a lot of surround activity and they really opened up my room. They really add substance but.......I will continue to audition them and will give feed back soon.
  • gtbiker
    gtbiker Posts: 15
    edited January 2003
    Ok, here's my test results. I really love the Def Tech BP2X's bi-polars. They really expanded the back of my room and put you in the middle of the viewing area. Of course I'm not knocking the LSI bi-polars but if anyone is looking for bi-polar surrounds for a couple hundred dollars less the the LSI bi-po's, check out the DF BP2X. Check'em out in the gallery under "GTbiker". Go rent "Signs" to test out your surrounds. Bad movie but good for surround speaker testing.
