Wall Mounting LSi 9s
gandl
gandl Posts: 5
edited May 2008 in Speakers
I will be using LSi 9s as my surround speakers. I will need to mount them on the wall behind my listening position. I am looking for suggestions on how to do this- use brackets, shelves, etc. What method/brand have people used? Thanks.
Post edited by gandl on
  • mantis
    mantis Posts: 17,404
    edited May 2008
    I suggest you return them and get a pair of Ls7's. The 9's are 2 big for wall hanging and they have no factory bracket. They are very deep.
    If you must hang them on the wall, I suggest you have a shelves built and built strong. I don't like this Idea.
    You can also which we have done with the 7's is have the wall modified so the speaker can sit somewhat inside the wall. If you have a basement with the wall to the outside concrete and have more space, you can built in wall shelves to fit them. I don't like this idea it looked stupis in my opnion. If I had some pic's I would post them of that job. inwalls would have worked so much better.
    Inwalls are a excellent choice for rears. They are safe first off, no possible speaker falling on your head and possibly hurting someone really bad and they sound fantastic when properly installed.
    Using 9's for rears and trying to hang them on a wall just isn't a good idea man.
    Dan
    Dan
  • Phasearray
    Phasearray Posts: 437
    edited May 2008
    They would look like wall tumors
    Receiver - Onkyo HT-R340
    Front - Pioneer S-HF21
    Center -Onkyo SKC-340C
    Surround Back - Polk R15 <--Ticket to club polk
    Subwoofer - Onkyo SKW-340
