Atrium 45: Horizontal or vertical?
EFanning
EFanning Posts: 60
edited May 2008 in Speakers
A friend just bought the Atrium 45s on advice from me. We set up 16-gauge wire from a 40-watt per channel receiver last night. The speakers will be mounted about 20 feet apart under a small overhang on a brick wall and face out toward a deck.
The friend wants to mount them two feet under the overhang. I'm telling him to mount the speakers horizontally so they can be angled down toward the deck. Which end of the speaker, logo end or no logo, should be pointing at the other speaker in the horizontal mount setup?
Also, is he better advised to go vertical and move the speakers down a bit to earn a proper swivel action?
Also, I bought indoor 16-gauge wire that is only patrially exposed to light and rain in this setup. Is that a big deal?
Thanks.
Marantz DV4001 CD and DVD
WD TV Live Hub with 1 TB (Need DacMagic)
Marantz PM7001 Integrated amplifier
Philips GA 312 Turntable
Polk Monitor 70s (Zone 1)
Polk Monitor 40s (Zone 2)
Post edited by EFanning on
  • jgido759
    jgido759 Posts: 572
    edited May 2008
    I have had my Atrium 45s for about 4 years. They are mounted 1 1/2 to 2 feet below the roof line, horizontal, about 15 feet apart with the tweeters towards each other, and angled down toward the picnic table (listening area). Bass is OK but not great (didn't expect it to be) and they work well for background music during outdoor parties and activities.
    Oh, you hate your job? Why didn't you say so? There's a support
    group for that. It's called EVERYBODY, and they meet at the bar.
    -Drew Carey
    There is a very fine line between "hobby" and "mental illness."
    -Unknown
    My DVD Collection
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2008
    It doesn't matter about the actual orientation since that's personal preference. I have mine mounted horizontally with the tweeters towards the outside.
    I would suggest "tinning" the ends of that cable with solder prior to installation. The cable will still corrode eventually but you should get some good life out of that.
  • mantis
    mantis Posts: 17,568
    edited May 2008
    dorokusai wrote: »
    I perfer to use spades or banana ends with shrink wrap to prevent this.
    Dan
  • zingo
    zingo Posts: 11,258
    edited May 2008
    mantis wrote: »
    Ditto on my outdoor speakers.
    Since you are not going to critically listening (I am assuming), install them to whatever works best for you.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2008
    dorokusai wrote: »
    I like Doro thinking here since its what I do. :)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • EFanning
    EFanning Posts: 60
    edited May 2008
    Thank you.
    The speakers will be mounted horizontally with the tweeters facing one another.
    The indoor wire may be "tinned" and will certainly be somehow inexpensively encased.
    You know, another friend told me that indoor wire used outside is a fire hazard because it could short out the receiver. What's up with that?
    Clearly, I don't want to spend more cash to buy proper 16-gauge wire for my friend's speaker set up. But am I putting his receiver or speakers at risk? Any advice on how to solve this one?
  • brijenjas
    brijenjas Posts: 311
    edited May 2008
    What receiver is it?
    Most receivers have a "protect" mode that they will enter if any speaker wires short, or if the impedance is too low.
    Unless it's some really cheap no-name receiver, I don't see it being a fire hazard.
    Oh, and welcome to Club Polk. ;)
  • EFanning
    EFanning Posts: 60
    edited May 2008
    We got the HK 3250 pushing the Atrium 45s. It's an older model Harman Kardan unit. It's not great. It's not terrible. May have a protect mode, I'll check it out. Here's the product page:
    http://www.harmankardon.com/product_support/support_detail.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=HK3250BLK&sjump=&#active
    You know, we took this outdoor deck system for a test run last night, and the A45s sounded like outdoor speakers, meaning there was a slight hiss and as volume went up, the sound got muddy. I am assuming that's due to the improper speaker wire set up or the 40-watt per channel receiver. We'll figure it out but if anyone's has some suspicions, let me know.
    Good times.
  • jgido759
    jgido759 Posts: 572
    edited May 2008
    I'm powering my Atriums with an old Yamaha RX-V595 (70W to all channels) using the "B" speaker terminals. Never noticed any hiss at any volume. Connected using about 50' of 14 gauge speaker wire through the attic. Banana plugs from receiver to wall plate in the house, bare wire at the speaker end.
    -Drew Carey
    -Unknown
    My DVD Collection
  • dorokusai
    edited May 2008
    No problems here either.
  • G-force
    G-force Posts: 82
    edited May 2008
    I have 5 pair of atrium45 on my deck and in my garage. I'm running a couple pairs of them diagonally so the sound will go both downwards and in. Seems to work great for me. I love the atriums.
    I'm running them off of an Adcom 565 pre-amp to an Adcom 555II 2 channel amplifier. I'm using an Adcom selector and it has no problem powering all 5 zones at once. Never noticed any hissing.
  • dorokusai
    edited May 2008
    Nice setup and gear G-Force....wow :)
  • jgido759
    jgido759 Posts: 572
    edited May 2008
    G-force wrote: »
    Nice. Never thought to try diagonal. :D
    -Drew Carey
    -Unknown
    My DVD Collection
  • EFanning
    EFanning Posts: 60
    edited May 2008
    The final chapter ended with a horizontal mount about a foot under the roof overhang with the tweeters facing each other. The brick wall backing produces acceptable bass and a good sound range. The 16-gauge indoor wire remains in place but must someday soon be replaced with 12-gauge white from Blue Jeans Cables. And a speaker-wire upgrade will require a more powerful receiver, which I might be able to give to my friend.
    Anyay, I got my buddy on the Polk Road and he may never get off.
    F1nut Posts: 52,033
    edited May 2008
    I would also suggest using banana's with adhesive lined shrink wrap for a virtual waterproof seal.
    As for the hiss/muddy issue. You are most likely turning the volume up too high for what the receiver can cleanly put out.
  • dorokusai
    edited May 2008
    I like the heat shrink idea alot, great suggestion.
