Car oxidization problem
ben62670
ben62670 Posts: 15,969
edited April 2008 in The Clubhouse
Well I haven't been driving it, and my car has real bad oxidization. What do you guys recommend for clearing it up?
Ben
Ben
Post edited by ben62670 on
    heiney9 Posts: 25,450
    edited April 2008
    A Clay Bar system. Is it black? I've had 2 black cars and both have had serious oxidation issues.
    I used a clay bar system and it was 3 step process that I ended up doing over a Saturday and Sunday. Keeping the car indoors between each polishing/waxing session. I did it ALL by hand and it was PITA. Get a power buffer to save your sanity and your muscles.
    I believe I used Meguires products.
    The 2nd car I paid someone to do it because it's very labor intensive if you don't have a power buffer.
    The car looked like wet glass when I got done so it works great. Do a Google search for clay bar detailing.
    VR3 Posts: 29,448
    edited April 2008
    Wax it regularly...
    That would truly help prevent it from happening...ever.
  • Jstas
    Jstas Posts: 14,985
    edited April 2008
    Wax it regularly...
    DING!
    But I've used Mother's 3-step process and it works great. You get even better results with a $40 power buffer too. I've used the clay bar too and did not see results that were worth the extra effort needed. I also have reservations about rubbing a brick of dirt on my paint. I usually take precautions to keep cleaning supplies free of dirt to avoid scratching the paint.
    Expert Moron Extraordinaire
  • MikeC78
    MikeC78 Posts: 2,315
    edited April 2008
    Jstas wrote: »
    DING!
    You don't just rub the clay on the paint, that's really not exactly how it's done. You need to keep the paint wet, by using a product it comes with, or by using running water, you need to also kneed and replace the clay when it gets dirty. No need to "rub" really hard, you are actually gliding the clay bar over the wet surface, if you rub, you'll only leave clay residue behind and obviously scratch the paint in the process.
  • Fireman32
    Fireman32 Posts: 4,845
    edited April 2008
    Go with the clay bar from meguires. Ive used it many times with great results. Be careful with a buffer though you can burn the paint if you are not careful.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited April 2008
    Mothers clay bar will be better compar them side by side and I saw the difference. They both do the same thing only mothers gets more out of the paint.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • MikeC78
    edited April 2008
    I used both, I also personally like the Mother's clay bar better. The clay seemed to "pull" more contaminates, and not stick as bad as the Meguires product.
  • Jstas
    Jstas Posts: 14,985
    edited April 2008
    Fireman32 wrote: »
    You are not going to burn the paint with a buffer. It does not move fast enough and has a random orbit. A polisher will burn the paint and grind right through to bare metal.
    A buffer, even with a dry foam applicator pad, will not burn paint. The sun beating down on your paint in an open parking lot on a 90+ degree day will heat your paint up more than a random orbit power buffer.
    This is a power buffer:
    They can be direct drive or random orbit. I have not seen a direct drive since the early 80's. They are safe to use on pretty much any modern automotive finish. They cause problems with lacquers and varnishes though but unless you have a car from the early 50's and earlier with original paint, I doubt you will have a problem.
    You will have a problem with these.
    This is a random orbit polisher:
    This is a non-random orbit polisher:
    These are essentially glorified angle grinders with foam pads. They operate at high RPM's and if you are using these to apply wax or other kinds of paint cleaners and conditioners, you are using it incorrectly. Even with polishing compounds, these will damage your paint. That is the whole intent, to take a small layer of paint off and reduce the scratching, pitting, UV damage and excessive oxidation. You will cause yourself to have a very expensive repair if you do not use one of these properly. They are very effective and produce outstanding results if used properly. They will destroy your finish if used improperly.
  • cmy330go
    cmy330go Posts: 2,341
    edited April 2008
    The clay bar will likely do little for the oxidation issue. Though I still recommend doing it, the primary purpose of clay bar is to remove small particles that have been embedded in the paint.
    After running a clay bar over the car I would then use a good quality car POLISH not wax. A polish will remove oxidation and fine scratches from the surface. Then when you're done with that apply a good quality wax to prevent it from happening again.
    From personal experience I have yet to be disappointed by a single Meguiars product. But as mentioned above Mother's also makes good car care products.
    Hope this helps.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Jstas
    Jstas Posts: 14,985
    edited April 2008
    MikeC78 wrote: »
    I know how they work and I don't care. Like I said, I have serious reservations about rubbing a brick of dirt on my paint. Whether it's "gliding" and lubed or not, you are still slapping dirt on your car and running it across the paint. I have used clay bars and after running a Mother's or Meguiar's 3-step process, I have seen very little benefit if at all from them. I don't use them and I don't recommend them.
  • nikolas812
    nikolas812 Posts: 2,915
    edited April 2008
    Jstas wrote: »
    Thats funny because that is all we use in our body shop. And it is also what the auto paint supply store sells.
    The power buffer you recommend is a joke.
    But...... They are good for inexperienced people.
    As for the pro... I don't think you will see anything but what you call a random orbit polisher in the body shop.
    They will only damage paint if you don't know what you are doing.;)
  • MikeC78
    edited April 2008
    That goes the same way with waxing, you'll be rubbing the dirt/grime in the paint with the cloth if you don't clay. The clay will "pick-up" the particles. The key is keeping the clay and paint wet at all times, you'll not scratch the paint unless you completely don't know what you're doing.
    No need to get all defensive, or come off as a know it all, I'm not attacking you, relax. I'm trying to educate the OP or others who have never used them before.
  • bigaudiofanatic
    edited April 2008
    I agree 100% MikeC78 wash clay wax there you go.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Jstas
    Jstas Posts: 14,985
    edited April 2008
    nikolas812 wrote: »
    I didn't recommend anything. I explained the difference between a buffer and a polisher. A buffer is not a joke and they work very well. Especially if you have a large vehicle to work on. My vehicle has an immense amount of paint and if I do it by hand, it's about 12-14 hours of work. If I use my power buffer, it's down to about 3-4 hours. They are meant to approximate a hand waxing job. There is no need to polish an entire car every time you want to wax it and unless the oxidation is excessive, there are plenty of products on the market that will fix the situation. Besides, no body shop I know will waste time with a car if all it needs is a good cleaning and a wax job. They will sooner refer you to a good detailer than take the work in for themselves.
    If you are using a random orbit polisher to wax your car and are an experienced professional, then you have just given the exception to the rule. If you are a pro then obviously you have the experience to know how to use it properly. I still think you are taking an unnecessary risk but that is just my opinion. But, for every "pro shop" you can show me that abhors the use of a random orbit buffer and thinks it's "a joke", I can find you an equal number that thinks using a random orbit polisher for a wax job isn't the brightest idea in the world either.
    I'm not looking to start a pissing contest or get into a big, chest thumping argument on who and/or what is better at what. I'm just interested in dispelling misinformation and giving solid, real world advice. If this was a board full of professional detailer and paint finishers, you wouldn't even see me post anything. This is an audio board and I have more experience with fixing and refinishing all kinds of surfaces on all kinds of things than most people. Am I a pro? No, I'm not but I'm not going to give bad advice either. If I am not sure what needs to be done or what the proper equipment is, I'll defer to someone with more experience than me. But my experience comes from doing things the hard way sometimes and even **** it up. I'm just trying to keep people from making obvious mistakes or repeating the not-so-obvious mistakes that burned me in the past too.
  • nikolas812
    edited April 2008
    Jstas wrote: »
    Fair enough.;)
    I probably took offense to something I shouldn't have.
    You are right though.. We don't wax anything. If we do it is our own cars and by hand with a meguiars paste wax.
    The only time we use the polisher is for a show car or if there are imperfections(dirt) in the clear after we paint a car. Then we will wet sand and buff them out as needed.
    Sorry to derail your thread Ben.
    I can't really give any good advice for oxidation.
    Anything that comes in the body shop with oxidation usually gets wet sanded and buffed or completely repainted in the bad areas. Which is something I wouldn't recommend to a novice.
    Good luck though. There seems like plenty of good adivice here so far.
    Or at least a debate on using clay.:D
    edited April 2008
    Wax it regularly...
    Not really. It will keep a car nicer longer, but black cars in particular will oxidize even if you use the best wax regularly. Now if you car is a show car and doesn't really get out in the elements.......then yes.
    As mentioned the Meguires 3 step process seems to be the best and yes if using the clay bar there is a solution you use with it.
    edited April 2008
    MikeC78 wrote: »
    Have you encountered Jstas before................that's his modus operandi; resident know it all with a very short fuse. Entertaining at times but he needs to let things go; he's wound way too tight!! :eek:
    edited April 2008
    Jstas wrote: »
    You should try it; when done properly the results are better than you could ever get with waxing and polishing. Use Google; you'll see your reservations are completely unfounded.
    I've used it (properly) on several black cars (which tend to show more scratches than most colors) and it does a SUPERB job.
    If you had issues perhaps you weren't doing it correctly.
    edited April 2008
    Jstas wrote: »
    The clay bar process gives the best advantage if you have moderate to heavy oxidation. Perhaps because of the color of your car and the age there was very little oxidation.
    Lighter colors don't seem to suffer as much oxidation as say a black or gray car. The 2 black cars I owned oxidized very quickly and the clay bar worked flawlessly.
  • MikeC78
    edited April 2008
    heiney9 wrote: »
    I guess we all don't know jack **** around here, and when he posts we can't post a response.:rolleyes:
  • Jstas
    Jstas Posts: 14,985
    edited April 2008
    What's the problem? I said I don't like using clay bars. I HAVE used them and saw minimal benefit. I don't recommend them because even when used properly, I still don't see the benefit. I'm allowed to have my opinion. I haven't tried to dissuade anyone to not use them, I have only said my findings were not as positive as others and I forgo the use and still get exemplary results.
    Search the internet all you want, you can find as many people saying they don't work as you can finding people who swear by them. All I said was that I don't use them and I don't recommend them. I'm not telling anyone not to use them, I am just saying that if someone asks me about clay bars, my answer is neutral and my experience was nothing to write home about so I don't bother. Added work for little benefit. If that makes me a "know-it-all" then everyone else here is too 'cause I have done nothing different. I just happen to have a differing opinion so that automatically paints me in a negative light because I don't agree with the masses.
    One last thing, heiney9, don't confuse UV damage with oxidation. UV damage is more pronounced on black cars because black is the absence of color and absorbs all light. The darker the color, the more UV light gets absorbed to damage it. It looks similar to oxidation but oxidation is a chemical breakdown of the paint due to corrosion caused by oxygen in water. UV damage is caused by UV radiation weakening the molecular bonds of the molecules in the paint and causing them to break down. No amount of polishing and waxing will fix UV damage. Darker colors are more susceptible to UV damage. Any color can oxidize and it's usually a result of negligent care of the painted surface and the affects of things like dirt from exhausts and road dirt interacting with lovely stuff like acid rain or just rain. If you live near an ocean, saltwater does it too.
  • cmy330go
    edited April 2008
    Taken directly from Meguiar's FAQ.
    7. Does clay remove scratches and swirls?
    No, clay does not remove scratches and swirls. Keep in mind, scratches, swirls, oxidation and stains are all imperfections that are below the surface and require a specialized paint cleaner such as ScratchX or Deep Crystal Paint Cleaner. Clay, on the other hand, is designed specifically for above surface bonded contaminants, such as tree sap mist, industrial fallout, over-spray and road tar. It is important to evaluate your surface to determine which method of imperfection correction your paint may require. In some cases your vehicle may require the use of both clay and paint cleaners for optimal results.
    My recommendation is to just go to Meguiar's site and do some reading. You will find far more accurate and concise info there.
    HT
    2 CH
  • bigaudiofanatic
    edited April 2008
    Looks like clay works for me. "one of my detailing jobs.":D:rolleyes:Before After
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    edited April 2008
    Jstas, in your opinion is UV damage reversible? The reason I ask is after using the 3 step process with the clay bar my paint looked new. It was very deep and glossy which led me to believe most of what I removed was oxidation. I'm sure with it being a black car there's probably a bit of both going on. It was my understanding that the clearcoat gave some protection to UV damage.
    I have seen black cars with what I assume is severe UV damage because the paint is almost purple in some areas and look faded and worn. That is not what is going on with my black car. After the process it was a very deep finish, high gloss and I could see my self in the paint.
    You are correct proper washing and waxing will keep oxidation from building up quickly but it will eventually. It does depend on where you live, if you car is kept in a garage and for me in the Midwest the weather is brutal to a paint job even if you take proper care.
    edited April 2008
    cmy330go wrote: »
  • bigaudiofanatic
    edited April 2008
    Or mothers www.waxforum.com
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • ben62670
    edited April 2008
    Thanks guys. I was kinda planning on using Mother's. When I got the car it was pretty rough. I will have to do before, and after shots on this one. It is a medium green. The paint is fairly thin. Hopefully I can resurrect it without doing too much damage.
    Ben
    Ben
  • Jstas
    Jstas Posts: 14,985
    edited April 2008
    heiney9 wrote: »
    Call a body shop and ask them. I don't need to be called a "know-it-all with a very short fuse" and "wound too tight" and then asked for my opinion all in the same thread.
    edited April 2008
    Jstas wrote: »
    Well so much for for the olive branch and trying to be civil.
    Have a nice day!
  • jflail2
    jflail2 Posts: 2,868
    edited April 2008
    heiney9 wrote: »
    Have a nice day!
    What else can you do....
    It's been an interesting read anyway.
