polk audio fuses
bakvee
bakvee Posts: 2
edited April 2008 in Troubleshooting
Hi all am new to this.Where do i have to get a fuse for a polk audio pws250, just got it from a friend and the fuse was missing.
Post edited by bakvee on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited April 2008
    Hello,
    It is a 1.0 Ampere/250 Volt slow blow fuse that is 5mm x 20mm, often called a "metric" size fuse. I've been in well-stocked Radio Shacks that carry all fuse types. If you have a good electronics parts store in your area that would be another source.
    Regards, Ken
