Negative effects of zip ties?
BaggedLancer
BaggedLancer Posts: 6,371
edited April 2008 in Troubleshooting
Anyone know any negative effects of zip tying cables to an audio rack? I'm tired of looking to the back of my rack and seeing all the cables so I want to neaten them up and zip tie them to the stand so I don't see them.
Other than being a PITA to change cables, are there any sound quality issues by having the RCA's against the metal of the rack?
Post edited by BaggedLancer on
  • dave shepard
    dave shepard Posts: 1,334
    edited April 2008
    none that I know of... as long as the power cables are not included in their.
    Dave
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    Sniff too much glue today dude?
    F1nut Posts: 52,009
    edited April 2008
    I like seeing my big, thick cables.........says manhood! :D
  • dorokusai
    edited April 2008
    I feel dirty after reading that.
    F1nut Posts: 52,009
    edited April 2008
    Take a shower. :)
  • BaggedLancer
    edited April 2008
    k good, I just zip tied all the power cables and RCA cables to the stand. :) Looks much better seeing no cables through the back.
    I know it was a stupid question, but had to make sure for grounding, interference, etc.
    I guess the biggest thing i was curious was because the stand has only 1 vertical in the back, so I was zip tying the power cables down the left side and the RCA cables down the right side on the same pole....so I guess technically you could call them in the same bunch....probably should have been more clear. The power cables and RCA cables are about 2.5 inches apart now....too close?
    F1nut Posts: 52,009
    edited April 2008
    You'll be fine.
  • SBrown712
    SBrown712 Posts: 202
    edited April 2008
    I use these. Easy to take off with the velcro ends.
    http://www.antonline.com/p_F8B024-GP_84456.htm
  • BaggedLancer
    edited April 2008
    You'll be fine.
    Thanks for the comfort Jesse. Can you sing me a bedtime story now? :p
  • pearsall001
    pearsall001 Posts: 5,328
    edited April 2008
    As long as your refrigerator is on a separate line...you'll be fine! ;)
  • SolidSqual
    SolidSqual Posts: 5,218
    edited April 2008
    The biggest negative I know regarding zip cables is the hassle required to undo them and redo them if you decide you want to move or rearrange your equipment. If everything is permanently where you want it to be then I say go for it.
  • pearsall001
    edited April 2008
    SolidSqual wrote: »
    Boy oh boy!! how true that is. I used zip cables at first thinking that I wouldn't be making any changes. Wrong! What a pain it was having to break out the scissors to cut them (very, very, carefully). That was a quickly learned lesson. Now it's velcro ties & any changes are now a snap. Just do your best to keep PC's away from analog/digital cables & there won't be any problems. Having everything neat & tidy is high on my list also.
  • Deadof_knight
    Deadof_knight Posts: 980
    edited April 2008
    go get you some of those computer cord velcro things from walmart !!!!
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Face
    Face Posts: 14,340
    edited April 2008
    SBrown712 wrote: »
    Home Depot has them for dirt cheap.
    F1nut Posts: 52,009
    edited April 2008
    That would be, no.
  • janmike
    janmike Posts: 6,146
    edited April 2008
    Those velcro straps work great. Pick the colour to blend in with the cables and you will hardly notice them.
    Michael ;)
    NORTH of 60°
  • liquidimpulse
    liquidimpulse Posts: 10
    edited April 2008
    when its time to rewire with added equipment, theres always the added hassle of cutting the zip ties and redoing them to fit all you're new inputs/accessories to your HT setup, I'd rather go with the velcro just in case
  • Rivrrat
    Rivrrat Posts: 2,101
    edited April 2008
    I have seen ties on coax cause problems if they're too tight and then the cables are moved.
    Since then I don't tighten ties down too tight on signal carrying cables.
    My equipment sig felt inadequate and deleted itself.
