Optimal Height for surrounds??
shimey013
shimey013 Posts: 79
edited March 2008 in Speakers
Ok, I have an FXi A4 as my surrounds...Im trying to figure out if there are speaker stands available for them, if not, i found some glass corner end tables that have a 31 inch height...they have glass shelves too..
so im curious on a couple things...
Would the glass shelves have an impact on the sound?
Are their speaker stands available?
If i could mount them on the wall i would, but i cant :(
Thanks for your help.
Post edited by shimey013 on
  • J_Kennedy
    J_Kennedy Posts: 138
    edited March 2008
    Look at THX and Dolby's sites.
    Height for Surrounds are generally said to be optimal at about 2' above your listening ear position. 5' to 7' from the floor is about the range. Mine are 6" to the floor to the bottom of the speaker. That's just high enough for most people to not bang their head. :D
    If I had a dedicated HT room, I'd build it so I could put them slightly lower, like 5', assuming the listening height was the same.
    - Onkyo TX-SR805
    - Polk RTi8's Main L/R's
    - Polk CSi A6 Center
    - Polk FXi3 Surrounds/Rear Surrounds
    - HSU VFT-2 MK3
  • Systems
    Systems Posts: 14,873
    edited March 2008
    Generally it is recommended that the surrounds be atleast 12" above ear level when seated.
    Testing
    Testing
    Testing
  • SlowcarIX
    SlowcarIX Posts: 887
    edited March 2008
    yamaha recommands 6' off the ground
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • shimey013
    shimey013 Posts: 79
    edited March 2008
    Yea, it kinda sucks when wall mounting isnt an option
  • Face
    Face Posts: 14,340
    edited March 2008
  • mantis
    mantis Posts: 17,394
    edited March 2008
    72 inches works in most cases.That measurement is to the tweeter. It's the most directional sound in a surround speaker. But the 3 foot rule above seating listening works great.
    Surrounds work best if they can be placed on the sides of the listening area. they work in the back of the room but I always feel like there is to much space in the movement of sounds. If you play a good demo, and try both locations, you will hear what I'm talking about.
    Dan
