RT600i base repair
cambir
Any suggestions on how to repair peeling on the base of an RT600i?
I would assume a glue/adhesive of some kind and something to hold it in place while it dries, but is there a particular type of glue I should use (or one that Polk uses or suggests)? Any ideas on how to secure it while drying?
Post edited by cambir on
I would try a superglue that is suggested for plastic on the package. It would tack almost instantly and, if it's rated for plastic, shouldn't melt or discolor the plastic. If it does not tack instantly, I would use some blue painters tape and wrap in around on-top of it to hold it.
Thanks Jake for the reassurance - I was thinking the same process.
Anybody ever tried super-gluing the base covering on their RT series? -
Turned out ok...not perfect, but much better than before.
Maybe hit the edge with a black sharpie to finish it off.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5.
