Speaker stand setup question
Want to setup my RM6000 satellite with a B-Tech BT10 speaker stand but the bolts included do not fit the threaded hole in the back of the RM6000 speaker.
Does anyone know the size (length & width) of the screw/bolt required?
Post edited by clsgman on
Most stands come with general size screws.You'll have to call Polk inorder to get the correct size.
I'm not experienced with the stands you own,but velco works good.Industrial.Dan
