receiver vs. amp for RTi10s
dcacc
dcacc Posts: 45
edited March 2008 in Speakers
I have an Onkyo 805, which is rated at 130 watts per channel. With it being 130 watts, would I need to get an amp with more power than that to hear an improvement in my RTi10s? I see so many people touting the advantages of dedicated amps, but would it make any sense to use a 100 or 125 watt two-channel amp -- would I hear any improvement?
Post edited by dcacc on
  • dorokusai
    dorokusai Posts: 25,577
    edited March 2008
    I'd stick with the TX-SR805.
  • mantis
    mantis Posts: 17,208
    edited March 2008
    Probably not much or worth the asking cost. Honestly you would hear a tonal difference with a better receiver or seperates. Most of your tone qualities from gear is in the preamp section. Running a amp with Onkyo , it will still sound like a Onkyo.
    Dan
  • devani
    devani Posts: 1,497
    edited March 2008
    save that money!! give them to me:D:D
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • PSOVLSK
    PSOVLSK Posts: 5,243
    edited March 2008
    I have an H/K 7300 and I added an Adcom 6000. No noticable difference in sound, but I didn't expect to hear a difference. My H/K was running pretty hot and I wanted to take a little pressure off of it.
  • Kchill
    Kchill Posts: 262
    edited March 2008
    You know I have a Onkyo amp that says it pumps out 130 w per channel. How do I know this is true, how can I measure this?
    I often heard that H/K with its modest 45 and 60 wpc is more accurate than Onkyo and others bloated wpc.
    Retired Onkyo 520 (returned broken HK 247)
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
    "Inch by inch lifes a cinch, yard by yard life is hard"
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2008
    Kchill wrote: »
    Kchill, I believe you have a 5xx series Onk. At best, it's putting 75w into 2 channels. Probably about 30w all channels driven. Entry level HKs do have more "presence" than that AVR...I owned it too. If you move up, get at least the 2xx series HK with pre-outs.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
