B&K Parts?
jakelm
jakelm Posts: 4,081
edited March 2008 in Troubleshooting
I emailed B&K about an issue with a potentiometer on the #2 channel of my AV5000. They responded saying that they cannot sell parts and I would have to send the amp in.
The pot knob, has to be pulled out slightly to work. When the turning knob springs back in a milimeter , the channel quits working. So I'm guessing it will have to be replaced. But no where can I find a spec sheet on the pot value. parts express sell about a billion of them with all different values.
Help would be appreciated.
Other than this, I absolutly love the amp. I just hope I can find part values, to replace this peice and maybe do a refresh on the amp.
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • AndyGwis
    AndyGwis Posts: 3,655
    edited February 2008
    I had the same situation. One of my older B&K amps had it's power switch go out. The amp worked perfectly, just the light wouldn't come on anymore. I asked B&K if they could sell/send me a replacement switch to try out, and they said to ship it in.
    Yeah, I really want to ship a 30 lb, 25 year old amp back and forth AND pay your diagnostic fee. Instead, I went to Altex, found one that fit well and a non-led switch, and problem solved for $3.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • jakelm
    jakelm Posts: 4,081
    AndyGwis wrote: »
    Exactly, 40+ lbs, especially when I can fix it myself.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    I wonder if there is a way to test a pot to determin the value. Wether its, 25kohms, 100kohms. etc....
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    heiney9 Posts: 25,221
    Isn't it B&K that has like a 20 year warranty? Or am I thinking of Bryston? Most of the larger electronics manufacturer's won't sell parts to an individual. Try contacting a repair center and see if they can sell the parts to you.
  • AndyGwis
    I think you're thinking of Bryston.
  • zingo
    zingo Posts: 11,258
    I bump heiney9s idea, try going through someone else, or ebay, on an online source.
  • jakelm
    jakelm Posts: 4,081
    All I need is the value. Partsexpress has the pot, and many of them, so I was hoping to get a spec/parts sheet, like I have for my Hafler amp.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Try posting/searching here
    www.diyaudio.com
  • jakelm
    jakelm Posts: 4,081
    heiney9 wrote: »
    www.diyaudio.com
    Thanks H9, I didnt think of that, I will try.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • WilliamM2
    WilliamM2 Posts: 4,782
    Why not just open it up, and bypass the pots? One less thing in the signal path.
  • jakelm
    jakelm Posts: 4,081
    WilliamM2 wrote: »
    Hmmmmm, what a good idea?
    The pot is set at max anyways. Is the auttenuation with the pot at max?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • WilliamM2
    That was my thinking, any amp I have had with level controls, was always set to max. And if one pot has failed, the others will probably follow. There is no attenuation at max setting.
  • jakelm
    jakelm Posts: 4,081
    There are 3 prongs for the pots. If I remeber correctly, the middle and the left are the 2 to connect? Thats if I am looking at the volume knobs on the front. Correct? But first I will try contact cleaner.
    I have never ran accross a pot that, I needed to pull out to make work, it either worked after spraying and turning, or did not work at all. Anyways.. A pic of the 2 leads to connect.
    But if I had the value, I could keep it original. Partsexpress has these.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • C3 Audio
    C3 Audio Posts: 43
    Hi,
    The down side of this is your going to have to pull the pot out to get its value. If you leave it in place and ohm it out, you'll get an false value due to other components in line or parallel to this pot. Pull it out and measure accross the two outermost connections. This will give you the value you need when replacing it. The center connection is the wiper and if you hook to it and one of the other sides, your reading will fluctuate when the pot is turned. Get the value and replace it with an equal size, value and tolerance from a supplier. Shouldn't be too bad if your familiar with soldering and an ohm meter.
    Best of luck,
    C3:)
    Conrad Johnson PV14L
    Rotel RCD-1072 CDP
    Carver TFM-25
    Polk SDA 1C's with upgraded xovers
  • jakelm
    jakelm Posts: 4,081
    C3 Audio wrote: »
    Hi,
    The down side of this is your going to have to pull the pot out to get its value. If you leave it in place and ohm it out, you'll get an false value due to other components in line or parallel to this pot. Pull it out and measure accross the two outermost connections. This will give you the value you need when replacing it. The center connection is the wiper and if you hook to it and one of the other sides, your reading will flutuate when the pot is turned. Get the value and replace it with an equal size, value and tollerance from a supplier. Shouldn't be too bad if your familiar with soldering and an ohm meter.
    Best of luck,
    C3:)
    Measure the 2 outer, and if bypassed, bypass with 2 outer. Thanks C3PO
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • C3 Audio
    C3 Audio Posts: 43
    jakelm wrote: »
    jakelm,
    Chances are, they are only using two of the three connections. One side and the center connection to attenuate the signal. If this thing is always at zero attenutaion, you could, as someone already suggested, short out the two connections being used until you can get a replacement pot. Just to be safe, I wouldn't use the shorting idea if all three conection are being used. They are being used if all three have been soldered in, typically.
    Yeah. Measure between the two outermost posts to get the value of the pot.
    Good luck,
    C3:)
    Rotel RCD-1072 CDP
    Carver TFM-25
  • bikerboy
    bikerboy Posts: 1,211
    Why not leave it in place and just bypass it? If you need it in the future measure it and get what you need then. You will probably want to replace all of them so you will have the matching values or rate of change. Also if one hs gone bad when will the others?
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
  • jakelm
    jakelm Posts: 4,081
    I will check tonight to see how many of the 3 leads are soldered to the board. If all 3 are soldered, I wont touch anything and just measure and replace. If only 2, I will bypass, being I run it all the way anyways...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Systems
    Systems Posts: 14,873
    It should have the value written on the body.Most use the blue pots made by BOURNS and these are easy to source if that is the case.If it happens to be a Bourns and you can get the value and the series number(ie.series91)I should be able to get one for you.Oh and it will be cheap.;)
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited March 2008
    GV#27 wrote: »
    Thanks GV, I tried over the weeked to bypass the pot, but was unsuccessful. All 3 leads are soldered to the board. I tried direct 1 and 3, 1 and 2 and 2 and 3, nothing yeilded a bypass mode.
    I also attempted to pull the pots off the board, but my patience ran out, trying to unsolder 3 leads quick enough to pull it off. I gave up for abit. I was able to get the pots working, but cannot be touched or bumped. Otherwise the channel kicks off.
    The pots are brown with no numbers on them. 2 of the 5 pots seem to have the brown plastic broken inside the pot, allowing it to be bent and twisted. Not good. But with alittle hot glue I was able to stableize it enought to put it in a fixed "max" position.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
