Should I put my rt35i's on large or small?
gplracer
gplracer Posts: 36
edited December 2002 in Speakers
Should I put my rt35i and cs400i on large or small? Here is my setup:
Onkyo 595
2 rt35i
2 rt5
1 cs400i
2 SVS cs+ subs
Thanks!!!!
Post edited by gplracer on
  • TroyD
    TroyD Posts: 13,077
    small
  • 19ram98
    19ram98 Posts: 18
    I would set them to small, setting at large is asking quite a bit from the rt35i's
  • RuSsMaN
    RuSsMaN Posts: 17,987
    How about trying both settings, and use the one that *sounds* better to you.
    Cheers,
    Russ
  • weavercr
    weavercr Posts: 289
    FYI the onkyo 595 sends LFE out at 80 hz when set to large and 120hz per tech support.
  • PETERNG
    PETERNG Posts: 918
    you got a good sub, let it do the hard work and let the RT35 relax and handle the mid and high, I agree with Troy, set it to small, you probably can hear the different right away.
  • danger boy
    danger boy Posts: 15,722
    Cheers,
    Russ
    Russman,
    you make things so difficult every time don't you? :lol:
    PolkFest 2012, who's going>?
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    I tried setting mine to large, changed it back pretty dang quick. On large the speaker sounded very very bright and I dont know...but small sounds alooooooooot better!
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • mantis
    mantis Posts: 17,200
    Small ALLDAY
    Dan
  • gplracer
    gplracer Posts: 36
    small it is!!!!! thanks!!!!!!!!!!!!!!
  • RuSsMaN
    So thats it? No listening test, just 'small it is?'
  • mantis
    I would hope he tried both ways and found that small is the better choice.
    gplracer,
    all of us in here just give you things to think about.It's up 2 you what works in your system.Alot of us have owned or still own the rt35i's.I did and in home theater mode I liked them in small.Music mode I switched back and forth as they where rears at one time in my system, sometimes large worked.In the end Surround back was there duty along with Multiroom music.Small worked.Does it for you?
    Dan
  • gplracer
    gplracer Posts: 36
    LOL! I tried it both ways and to me it sounded better on small than large. I did not try it for an extended amount of time on large though. The difference did not seem that great. I just thought I would get opinions because there might have been something I was not considering. Thanks!!!
  • scottvamp
    scottvamp Posts: 3,277
    WOW!!!!!!!
    SMALLit is!!!!!! :p
  • mantis
    I can respect it dude.You tried it,took what people said with a grain of salt,and in the end made up your own mind about how they should be setup.
    Great job my man.
    Dan
