rt-800 rubber feet
cabolton13
cabolton13 Posts: 72
does anyone have the rubber feet that go with the rt-800?i called Polk and they no longer carry them any help i would be grateful
MY SYSTEM
RT3000P
CS400 (2)
FX1000
Sony ST-SA50ES
Sony TA-E9000ES
Sony TA-N9000ES (2)
Sony BDP-S570
Sony LCD 46"
Technics SL-QD2
Monster HTPS7000
Directv HDTIVO
PS3
Xbox360
Wii
Post edited by cabolton13 on
  • Kex
    Kex Posts: 5,205
    edited February 2008
    This question has come up a few times before. Theoretically, IIRC, the spikes come with the rubber feet too (you pull off the rubber feet to reveal the spikes). Do c/s have any spikes for the RT800/800i? If the thread is the same, you could also use spikes (with rubber feet) from different Polk speakers.
    Check with nikolas812 too, he bought some RT600s which arrived broken. The spikes/feet are probably the same ones, and c/s could probably confirm that if Nikolas still has the parts.
    Alea jacta est!
  • cambir
    cambir Posts: 1,046
    The spikes for the RT600 are not identical to the spikes for the RT800i - the bases are designed a little different. The rubber feet, however, seem to be universal (regardless of the "i' series).
    The feet/spike set for the RT800i is part number BA0200-1. Did you use this part number when contacting Polk?
  • cabolton13
    cambir wrote: »
    no i did not i told them i have the rt800 and they said no
    MY SYSTEM
    RT3000P
    CS400 (2)
    FX1000
    Sony ST-SA50ES
    Sony TA-E9000ES
    Sony TA-N9000ES (2)
    Sony BDP-S570
    Sony LCD 46"
    Technics SL-QD2
    Monster HTPS7000
    Directv HDTIVO
    PS3
    Xbox360
    Wii
  • nikolas812
    nikolas812 Posts: 2,915
    I got some. I don't know what there worth though. Send me a PM and figure something out.
  • nikolas812
    Some are saying they won't work. The ones I have are for the RT600's. But I have had a pair of Rt600's Rt800's and RT800i's at my house all at the same time and I thought all there feet were interchangeable. Just PM me your addy and I will send them to you. If they work. Pay me. If they don't. Just keep them.
    Nick
  • cabolton13
    edited March 2008
    thanks nikolas812 for the rubber feet they worked perfect and at a great price.
    MY SYSTEM
    RT3000P
    CS400 (2)
    FX1000
    Sony ST-SA50ES
    Sony TA-E9000ES
    Sony TA-N9000ES (2)
    Sony BDP-S570
    Sony LCD 46"
    Technics SL-QD2
    Monster HTPS7000
    Directv HDTIVO
    PS3
    Xbox360
    Wii
  • nikolas812
    edited March 2008
    No problem.
    I am glad I could help.:)
