Question about my DSW Pro 600
ryanjoachim
ryanjoachim Posts: 2,046
edited February 2008 in Troubleshooting
I don't remember if I have asked this question elsewhere...but I figured I might as well ask it here.
I am using a Digital Coaxial cable (the kind you find for dvd players and such) to connect the LFE spot on my sub to the Sub port on my Onkyo 605 receiver.
Is that ok?
Is it any better or worse than using a regular RCA cable?
Also...my sub has the 2 red/white plugs, which I understand are RCA.
Now, they also have the 3 yellow/red/white plugs too...am I supposed to plug in a regular A/V rca plug into it? With the yellow plug? And if so...what do I do if my receiver only has the 1 plug for the sub?
MrNightly wrote: »
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
mystik610 wrote: »
Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
My System:
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
  • [Deleted User]
    [Deleted User] Posts: 0
    Using your sub out from the receiver to the LFE input of your sub is fine. That's all you need to get started. However there are other methods of connection but use what best fits your situation.
    Be sure to adjust your receiver speaker settings to what sounds best to blend with your other components. Play around with placement and the Room optimization settings. Enjoy that is a very nice sub.....
    Len
