Help removing tweeter connectors
Scudo
Scudo Posts: 2
edited February 2008 in Troubleshooting
Hi, I have a pair of M10s and I believe one of my tweeters is overdriven. I ordered a new tweeter from Polk and have it here with me. I am trying to remove the old tweeter but the connections on the back are very stubborn. They seem to be glued or somehow fastened to the little metal tabs on the tweeter itself.
I've tried a plier, but I'm afraid of damaging something. Is there any proper way to remove them? Or should I just pull?
Post edited by Scudo on
  • ben62670
    ben62670 Posts: 15,969
    Just grab the terminal where the wire is crimped, and pull. They lock on there pretty good. Welcome to Club Polk.
    Ben
    Ben
  • Scudo
    Scudo Posts: 2
    Excellent, that did the trick. I guess there was nothing to worry about after all. With the new tweeter in, the speaker sounds brand new. Thanks for the help.
  • ben62670
    No problem. Stick around, and get your read on. There's a lot to learn here.
    Ben
    Ben
