Bearly audible even at high volume!?!
echoreply
echoreply Posts: 2
edited February 2008 in Troubleshooting
Hello,
I figured I would try posting on these forums before I called tech support.
setup:
2x rti8
1x onkyo 605s receiver
Speaker wire is 16gauge from what I remember
Some older sony triniton crt (had to use composite cables to hook everything up)
some cable tv box
samsung dvd/vhs player
Alright, I'll try and recall as much as I can when I set this up for my parents.
Right now the 2 speakers are bi-wired to the onkyo. I've double checked the connections, the gold plated connectors are removed and sound is clear (no distortion/static/clipping as far as I can tell.
The receiver only puts out 90w a channel, yet if you are in stereo it supposedly puts out 110w (what I remember from the onkyo manual)
I ran the setup program with the mic and the distances (12ft from couch to tv) it got were accurate, so I assumed everything was fine.
I can't remember exactly, and i'll double check this next time I'm home, but I feel like if I do a test tone, the volume is more normal, but still on the low side.
Here's the problem
we have to put the onkyo receiver to 65 on the volume setting before it's comfortably audible. This goes for radio/dvd/tv. I had even put the two speakers to +12db (hopefully this doesn't damage) just so we could get it audible at 65. The volume on the cable box is set to max as well, if I put it any lower I would have to go into the 70's-80's...
This doesn't make a lick of sense to me as my home theatre in a box 7.1 with onkyo 505 receiver (some such sort) and those...even with 2 paltry rear speakers and free speaker cable going down to workout room...well they fill up the room with sound at 30.
Like I said, even though the volume is set at 65-70 it's still clean, I just don't understand why we have to put it so high and I'm worried that it's damaging the equipment on some level.
Any help would be great!
Post edited by echoreply on
  • ohskigod
    ohskigod Posts: 6,502
    simple suggestions
    make sure the speakers are hooked up to the right terminals on the reciever (left and right main)
    If your running 2 channel, make sure your reciever is in 2 channel mode (and not a multi channel surround mode like Dolby pro logic, diginta, DTS NEo etc. if its on a surround mode, and you only have 2 channels, i can see how the sound will come off muted.
    also, some recievers have a mute function, that significantly lowers volume (why, I have no idea). see if your reciever has a Mute button on it anywhere, or look in the manual to see if the menu function f the reciever has a mute selection. if it's on, turn it off (MAKE SURE THE VOLUME IS LOW OR OFF WHEN YOU DO IT!!, blown speakers are not fun :D)
    good luck bud, keep us posted
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • plarkinjr
    plarkinjr Posts: 3
    FWIW, I just got an Onkyo 605 and Polk Monitor 60's last week, and have noticed too that it takes a higher number than I expected on the Onkyo volume setting to get listenable sound. I was surprised, but it seems to work OK.
  • echoreply
    echoreply Posts: 2
    Thanks for advice. After doing a bit more searching around, it does seem that the newer onkyo rec at least this line does require the volume to be at around 50-60/100 before sound is at an acceptable volume. It just confused the crap outta me b/c my older onkyo would be listenable at 30. Thanks for the suggestions though!
  • danger boy
    danger boy Posts: 15,722
    newer modern day AVR's require more volume than older ones from about 15 yrs+ ago. don't know why, but they do.. my average volume is between 35 and about 29, but mine is **** backwards... ;) if I have it at -60 or so.. i can't even hear it.. mine goes from like -72 to + 10
    I wish mine was reverse.. whereby zero would be no volume and 70 would be max volume.. that i understand.. these negative volumes screw my brain up. :p
    PolkFest 2012, who's going>?
  • cfrizz
    cfrizz Posts: 13,415
    ROTFLMAO!!!!
    It confused the hell out of me as well Al!
  • lockmart
    lockmart Posts: 107
    echoreply wrote: »
    QUOTE]
    You have to remove a gold plated connector?
    TV Samsung 61" 1080P DLP LED
    TV Samsung 50" 1080P DLP
    HD-DVR
    Receiver Yamaha RX-V663
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
