Problem with miDock 10
listener
listener Posts: 1
edited January 2008 in Troubleshooting
My son has a miDock 10 and an iPod touch. He wants to use it as an alarm clock, but if he has the iPod plugged in with the miDock on without anything playing, there is a put-put-put sound from the miDock. Otherwise it sounds fine when music is playing.
Any ideas?
Post edited by listener on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited January 2008
    Hello,
    I've forwarded your problem to the folks in that product department and will let you know what they say.
    Regards, Ken
  • [Deleted User]
    edited January 2008
    Hello,
    Here is their response:
    "The touch and miDock10 are not really compatible. There is a fit issue.
    That said, my guess is this is the WiFi in the touch causing noise problems. I replicated this problem here, and it went away when I disabled WiFi."
    I hope this is helpful.
    Regards, Ken
