Harmony 670 set up
NeilGabriel
NeilGabriel Posts: 1,487
edited January 2008 in Troubleshooting
I always approach these problems with the fear of failure! Well, 3 weeks after Xmas, and after getting some new gear, I reconfigured my old Harmony remote and it seems to work well.
Then, I configured the new 670 for a second system. It seems like most functions work OK, though I could not do Play DVD because it would not change input on TV. A Panasonic. It is sending command InputComponent2, which seems correct, and the website set up shows the correct input settings for the TV. Other than trying to teach the Harmony the command, any ideas? Thanks.
P.S. it also does not turn on the CD player, but it is a 15 yr old Rotel and although the set up did not say so, I did not expect it to be in the data base.
Post edited by NeilGabriel on
