5 subs . maybe more
What do you think about more then 2 subs in a HT system. I currently have 3 Def Tech pro sub 8's for the LCR. And 2 Energy Subs for the LFE and presently in the rear. I'm accustomed to ALL of them and not thinking of getting rid of any. Also i'm thinking of replacing the LFE's for the Emotiva subs. Is this overkill???? Thanks for all who respond.
Post edited by jazzisnumberone on
  • polrbehr
    polrbehr Posts: 2,854
    edited January 2008
    I think you'll find people will tell you that there will be cancellation issues with that many subs, and that it's too difficult to calibrate them all.
    I ran two subs once upon a time, and even though (or because?) they were two different models and mfrs', it was too easy to localize the bass, especially in a h/t setup.
    Fast forward to last May... bought an SVS PB12-NSD/2 sub, sold the other two, and never looked back. Even in a 15 x 25 x 8 room, this thing can shake the foundation, but can also disappear when necessary.
    But, hey, whatever sounds good to you is all that really matters, right?
    And welcome to the Club. ;)
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2008
    I don't think it's overkill, as long as you calibrate them very well. As long as you cannot localize the bass and calibrate them for your room dimensions, I think that many subs is okay.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2008
    With that many subs, I highly recommend the Velodyne SMS-1
  • mantis
    mantis Posts: 17,593
    edited January 2008
    I don't like multible subs. I have installed multible subs and I find that more then 2 is overkill. Unless you have a movie theater size room in your house , you are wasting money or just not appling it correctly.
    If you own 5 subs, add the price of all those subs together and devide it by 2. Then shop for 2 subs of higher quality . This will yield way better results in the room. You also can take all that money and buy a really high end sub.
    Martin Logan Decent and Depth subs can fill a large room all by there selves with no help. I'm talking 16 x 25 or even larger. Once you hit 20 x 30 + you will need 2 of them.
    I suggest selling them all and getting a higher end sub or 2. After that your on your own.
    Dan
    Dan
  • MikeC78
    MikeC78 Posts: 2,315
    edited January 2008
    Sherardp wrote: »
    Velo works great with up to 3 subs only, otherwise you need to daisy chain another SMS-1 to work with 5 correctly.
  • Sherardp
    edited January 2008
    MikeC78 wrote: »
    or you could use a splitter on the other two, it would still work.
  • MikeC78
    edited January 2008
    Sherardp wrote: »
    You could, but then the subs that you have split on the SMS-1 will not be room corrected if you have them in multiple positions. It will only work with 3 subs colocated, should be able to get away with it if the subs are stacked.
  • Sherardp
    edited January 2008
    MikeC78 wrote: »
    Youre right, I didnt think that far ahead.
  • jazzisnumberone
    jazzisnumberone Posts: 53
    edited January 2008
    Thanks for all the replys. When i move(hopefully this year) things may change. New front display and possible electronics. This hobby evolves on a daily basis. It all comes down to your personal taste.
  • jazzisnumberone
    edited January 2008
    polrbehr thanks for the welcome...
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited January 2008
    I don't think it is overkill, just poor planning, akin to stacking speakers or running set A and B together in 2 channel mode. ;) Get 1 or 2 quality subs and call it good....oh yeah, welcome.
  • jazzisnumberone
    edited January 2008
    Oh well it has worked for me. Loving every minute of it.
  • jazzisnumberone
    edited February 2008
    Just finished watching Transformers. With all "those" subs it sounded so nice. And yes it doesn't cancel each other out. It's all personal preference.
  • ShinAce
    ShinAce Posts: 1,194
    I think you'd be happier with one or two big sub(s). Probably get lower and faihful extension, and plenty volume to not risk any damage.
  • Sherardp
    ShinAce wrote: »
    My thoughts exactly. Dual PB13s, Epik Conquest or even the PB12 Plus/2s on sale @ SVS.
  • jazzisnumberone
    How about 2 Fathoms.. (JL Audio)..
  • brijenjas
    brijenjas Posts: 311
    Sure, if you've got 5 grand to throw at subs.:eek:
