Help on rt2000p subwoofer amp
sooont
sooont Posts: 2
edited January 2008 in Troubleshooting
My son was showboating my rt2000p speakers and he accidentally shorted the golden tabs while trying to drive the sub cabinets separately.
Now the left speaker has a relay that basically clicks continuosly as soon as the amp detects a signal. Everything seems to be working fine, but of course if the volume on the amplifier is turned up the relay constantly kicks in. Bass is almost inaudible.
Is this a quick fix, any "obvious" signs I could look for if I decide to take the sub amp apart?
Thanks!
Post edited by sooont on
  • capitan100
    capitan100 Posts: 172
    edited January 2008
    I'd contact Polk customer service. They can probably fix it for you.
    Good luck
    Sony DA7ES 7.1 A/V Receiver
    Sony DVP-NC80V - SACD/DVD player
    CS400 - Center channel
    RT2000i - Fronts
    RT1000i - Surrounds
    a/d/s MS3/u - subwoofer
    Hitachi 62 inch HD TV
    2 Channel Room
    Niles HDL-4 Speaker Selector
    Niles HDL-6 Speaker Selector
    Sony V555ES receiver
    Sony DVP-S7700
    Polk SDA-2B
    Polk Monitor 5
    Thiel 03a
    B&W 2001 ZMF
    Signet SL-250 B/U
    a/d/s L400e
    Wharfedale Valdus 100SE
    Polk PSW 350 - subwoofer
    Pioneer Elite Big Screen
