Replacing LSI-15 Tweeter
gandl
gandl Posts: 5
edited November 2008 in Troubleshooting
I am contemplating buying a pair of LSI-15 speakers. However the tweeter on one has a deformed cone. Is the tweeter replaceable? If so where can I get a replacement and what would be the approximate cost? Thanks for any help.
Post edited by gandl on
    treitz3 Posts: 19,273
    edited January 2008
    I have a Vifa tweeter that I purchased from another forum member that I will not be using. I purchased it for $50 and I'll take $45 shipped. It has never been used. If memory serves, the replacement cost is somewhere near 100 smackers, but I'm not 100% positive.
    If you are interested, please post in this thread and I will PM you my information. Welcome to club Polk.
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Does the deformation cause a change in sound? If not, it is only a cosmetic replacement, and yes they are. Try treitz3's offer, solid member.
  • McLoki
    McLoki Posts: 5,231
    edited January 2008
    If the deal is decent enough, it is still a deal after you sink another $50-$100 into it for the tweeter, pick it up. If not, wait for a better deal to come along.
    (and welcome to club polk.)
    heiney9 Posts: 25,221
    edited January 2008
    zingo wrote: »
    Yes, I would say so based on the way the tweeter is designed the ring radiator (pointy nipple cone piece) is suspended at 2 pivot points so it's easily damaged.
    "The Ring Radiator Diaphragm -- Delivers flat response, precise detail and overall accuracy. The ultra-light woven diaphragm is supported at two pivot points (A & B), with the voice coil attached between the two points (C). With very little unsupported material, there's less opportunity for performance-robbing resonance to develop."
    At least that's my take on it.
  • ohskigod
    ohskigod Posts: 6,502
    edited February 2008
    deformed or not, just make sure sound comes out of it before you buy, if not, there might be a crossover issue. worth looking into before you buy
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • gtu2004
    gtu2004 Posts: 620
    treitz3, do you still have the tweeter?
    Onkyo 805, RtiA5s, Csi5, Rti6s
    No, it has since sold but I have answered your PM. Good luck and get back to me if I can be of further assistance.
